- Apr 3, 2011
Just finished this up! Peel ply g10 show-side scale in OD green for this skinny =)
What are your thoughts on working finish hardware on the front and copper/bronze on the back?View attachment 1055073View attachment 1055074 View attachment 1055075
LOL that is exactly why I’ve got the working finish hardware on the front now. Totally my fault and being impatient.I like my copper set of hardware butbe careful with the screws if you switch them out they can strip easily ... have to just snug them ... I used just a touch of Vibra-tite to try it ... otherwise a tiny bit of blue loctite if you end up using the copper screws.
I’ll probably eventually order three new scale screws. I was able to pound a T8 wiha torx into the one I fubarred up and get it out.well you aren't the only one that has done that ... I luckily learned from watching someone else install copper hardware and the famous last words I heard were "there just about done ... just snug this down a ... oh S***" ...
and then a new set of screws after I used an easy out to remove two he stripped ... so don't feel bad ...
but I do like that copper look ... I got some bronze to try but haven't installed them yet ... see how they compare when I get time.
I’ve got some easy outs and they work wonders! That was going to be my next step, if it wasn’t copper i highly doubt I could of pounded a T8 into it!yeah I have attempted that in non knife screws but I didn't have much luck ...
I have used JB Weld and welded a small nut onto a screw head several times but with these fitting flush and the size not sure if they would bond enough to break loose. ...
the easy outs and or grabits are great for most screws unless you get crazy hard screws then you're getting into the same hardness or the tools trying to remove them.
[/QUOTE]Hi,
Does your disassembly tool show any patina developing?
Hi,
I hope you can see the dark spots on top and side of the back spacer/tool. The blade on my Full Track is M390. I am not sure what the pin that holds the spring is made of but just to be safe, I applied a light coat of Frog Lube.
View attachment 1058868 View attachment 1058869
