From the Liquid Metal website (is the comparison to chrome relevant to knife blade coatings?):
Amorphous Metallic Coatings Prove Corrosion Resistant and Tough
A family of proprietary amorphous nanocrystalline metallic coatings, known as Liquidmetal® Coatings and developed in the United States by Amorphous Technologies, Inc., provide wide-ranging corrosion protection. Amorphous metallic coatings are further enhanced by their ability to resist abrasion wear and impact damage. These materials are applied using a thermal spray technique known as high-velocity-oxygen-fuel (HVOF) which produces dense, pore-free, hard, and tough coatings. The LMC materials are transformed into an amorphous nanocrystalline structure upon finishing or once they are put into service. When Liquidmetal Coatings are subjected to wear, once they have been put in service, they undergo the unique transformation that causes further hardening. Contrary to the traditional concept of wear resulting from usage, amorphous metallic coatings get harder, slicker, and more wear resistant as they are put into service. In addition, the surface hardness of LMC, after being transformed by service, has proven to be 10 to 20 percent harder than a hard chrome surface when compared and measured on a Vickers hardness rating scale.
Amorphous Coatings Outperformed Hard Chrome in Marine Setting
Amorphous metallic coatings subjected to laboratory simulated corrosive marine variables, such as fog and sea water spray, have outperformed hard chrome coatings. Seven-day tests conducted in a saturated sea water mist environment by Amorphous Technologies, Inc. demonstrate the superior performance of amorphous coatings. Samples of `as sprayed' and ground and polished amorphous coatings on steel and aluminium substrates were tested alongside samples of hard chrome-plated hydraulic rod and shafts (see photo). Post test examinations, using optical and scanning electron microscope (SEM) techniques, showed no indication of corrosive attack on the LMC-coated samples. Furthermore, a manufacturer of offshore value equipment documented the corrosion resistance of LMC in an ASTM B117 (American Society of Testing and Materials) Salt Fog Spray Test. An HVOF-applied amorphous coating of only three mils in thickness totally protected the substrate from corrosion during a six-day salt spray test by producing a barrier coating.
