Yup. And the other simple fact is that all anyone has to do to completely shut them up is to build a stronger lock.
All the lawsuit and other antics aside...this says it all.
To me , lock strength IS very important. I own more Spydercos than any other company, and the compression lock is my favorite. Furthermore, I I think it is a much stronger lock that the video portrayed it to be.
Umm....why do you think that, based on the video which clearly "portrayed" the strength/weakness of both knives??
That said, I trust my Cold Steel Triad lock knives much more than any others. They see the most outdoor use by far. I hike most weekends and do some trail running, and while I carry a fixed blade much of the time, sometimes I opt for a lightweight folder. The Triad lock just laughs off everything.
You think it is a much stronger lock that the video portrayed it to be, yet you carry the CS. Why would that be?.
Might be a bad contest if your goal is to show up Cold Steel on this one. Same stock thickness, same grind, but the Hold Out 2 has a broader blade which means a higher grind and a slightly better angle for slicing. Real world it would come down to which was thinner behind the edge and, realistically, that would probably go back and forth between the two based on the individual sample.
That's part of what cracks me up about Cold Steels marketing. Ignore that for a second and look at the knives they're actually making. They use thinner stock than many, many companies (Spyderco Military has 4mm blade stock, Recon 1? 3.5mm), the grinds and edges are generally much better suited to slicing than abuse and they've removed steel liners from almost every model they make.
Cold Steel licensed a tremendously strong locking mechanism so they market the hell out of it, but they clearly don't believe that strength is the most important aspect of a folding knife or their designs would be very different. I like Cold Steel because they make a broad range of simple, working knives that cut well are lightweight and are very reliable.
A lot of controversy over poor replacements for fixed-blade.
If we're talking about the blade not folding under load, use one that didn't need a "repair" as part of its construction. :thumbup:
No need to wave. Fast to deploy. Easy to clean up. Lighter for the same blade. Probably cheaper for the same blade.
I don't own either knife used in the video. Never held them either. I don't have a problem with objective testing but only testing the lock without showing the failure point of their own product shows how these videos are just more marketing trash. I would rather see tests for how the knives function as cutting tools rather than weight hangers. For all I know their knife will break at 1 lb more than the competition.
Spyderco has a well deserved reputation for producing quality knives. Cold Steel has videos of fat guys slashing hanging meat. I would like to see them focus on other aspects of knives and use less gimmicks. If their knives can out perform Spyderco flagship models then that is something to brag about. I would probably buy their knives if they could show that.
Folders are poor replacements for fixed blades. But many, if not most, of us cannot carry a fixed blade wherever we can take a folder. And if we accept the premise that any folder is a poor replacement, why wouldn't we want the best of the worst? Lock strength is a far cry from everything, but it's certainly not nothing.
But if you pic a knife that is called "Military" or " Para -military" then customers are being misguided on purpose toward their intended use. My five cents ..
Hmmm...some love to impress us with their erudite articulation. I hope someone can decipher that post. I sure can't.
The Military was designed as a utility knife for soldiers, not a fighter.
Look up the history of it...I'm not making it up.
The Civilian was designed as a fighting blade...so much for names.
Names are for marketing, right? The implication of "military" would not seem to be "kitchen implement."
Tatanka, a traditional Polish drink made with Żubrówka and apple juice.
Didn't expect you could.
