- Dec 30, 2009
The lock test videos have sparked a lot of discussion, and by Andrew's own admission a lot of hate mail. Personally I really enjoy them and it is interesting to see, I also like that they are doing their best to make the testing between the two knives in the same video as consistent as possible.
All that said, I think there is room for improvement and a few things that I personally would really like to see and I think others here would agree. First and foremost (and least likely to be delivered) I want all of the testing to include destruction of BOTH knives. If the CS knife outlasts the other cold steel has already won, but we'll never know by what margin unless they continue on until the cold steel knife has broken as well. This would be useful to know and then Cold Steel would be living up to the test they challenge everyone else with: think your knives are tough? Prove how tough they are. The relativity is nice but you can never run a true comparison unless you know what the actual breaking point is. You just know that this knife is stronger than that knife, by how much? Who knows?
Second keep your testing technique consistent from one test to another so that you can truly use the testing to rank knives on a scale. If the test isn't consistent then there is no comparing between results, because again it is all relative ONLY to the other knife in the video which obviously they are going to be selective and choose a knife they know will win. So what I mean by this is use a constant distance from the pivot for hanging the weight so that the torque is always going to be the same. I could probably hang 600 pounds from a delica if it was a tenth of an inch away from the pivot because the torque would be relatively small. Likewise saying a knife holds x amount of pounds is meaningless because that doesn't equate to the force against the lock. If I run my knife over with a truck does that mean it held 5000 pounds? But if they were to make the test so that the weight ALWAYS hangs 4 inches from the center of the pivot then you'd have a true comparison.
All knives are not equal and comparing a thin light folder to a heavy duty folder doesn't make sense so I understand tailoring the test to an extent for the knives. But really, rather than adjust the test to be more or less strenuous people just need to adjust expectations accordingly. If a Ti-Lite fails at 100lb's (just making this number up, have no idea what it really is) that isn't a big deal and if you keep the test consistent I will know exactly how that knife lines up to any other just by checking the failing weight.
I think you get the idea now, but just so I don't leave it out I think the same consistency should be expected across the board. Ex: spin wacks always hit the same distance from the pivot, same number of strikes same weight. And finally use a new knife for each test. Some knives are going to be more susceptible to different forms of punishment so it is unfair to cripple one and then draw a concrete result in the next test.
I like the videos because they are entertaining and it gives you a slight idea about two knives capabilities. But since they are doing all this testing anyway, why not start to build up some useful comparable data so that any knives that have gone through the cold steel gauntlet can now be compared?
