That’s the rare exception rather than the rule. Now if it were a spyderco...That moment when the copy is a little too on point!
Not one of my Benchmades has ever had QC issues. Idk where you guys are buying yoursHmmm, very much like a Benchmade indeed!
Even benchmades ive bought off eBay have been perfectly fine QC wise. Vs the one spyderco I’ve bought that was impossibly stiff out of the box. Maybe I’m the exception there but that was my first impression of spyderco and I was underwhelmedRead around guy. There are WAY more QC issues with Benchmade than Spyderco. Consider yourself lucky if you never had any QC issues from BM.
I have seen minor issues on Benchmade knives; the axis lock being the main culprit. The lock is basically a plunger under tension from the omega spring and has limited potential travel distance. If it reaches the end of its travel without camming against the locking surface on the blade it will have some limited blade rock between the stop pin and axis lock. Benchmade is generally pretty good, but they run a business and have to balance cost per unit and QC inspections. I suspect hippy Oregon has expensive labor costs and that has to be figured into cost per unit. IMO Benchmade is doing what it can to stay competitive and profitable, which unfortunately means costs have to be cut somewhere.Not one of my Benchmades has ever had QC issues. Idk where you guys are buying yours
Multiple companies make their knives to be competitively priced and are not made to Chris Reeve level tolerances. That said most of the time I can play with knives to adjust blade centering. Usually tightening a pivot or swapping a standoff is all you need to do. Sometimes they are just crooked and need to have parts swapped out completely or permanently altered, i.e. file work. Most people feel that items at that price point shouldn't need work of any kind and while I see their point I generally feel unsatisfied with most factory knives and expect to modify new knives. At minimum I will put a new edge profile on a knife at some point. Definitely annoying when the issue is "good enough" workmanship.Did the shirogorov axis lock knives have similar issues with centering?
If multiple companies seem to struggle with it, then I almost wonder if it is inherently difficult to get right
It is worth bringing up the question since Hogue is otherwise known for having marvelous F&F, and not "Good enough" workmanship.Multiple companies make their knives to be competitively priced and are not made to Chris Reeve level tolerances.
The "good enough" craftsmanship comment was aimed more at Benchmade. I am of the opinion they cut costs where they can and still turn out a "good enough" product.It is worth bringing up the question since Hogue is otherwise known for having marvelous F&F, and not "Good enough" workmanship.
Well I use my griptillian every day at work and it’s got no blade play. Maybe I should try throwing it at a wall? Anyway, I’d trust my Benchmade over the new Ritter any day but if I could find a decently priced BM Ritter I’d be all over it.Try a bit harder and then come to tell us if none of them has slight side to side blade play.
I wish I could convey it through a video but mine has no up and down or side to side. It didn’t when it came from the factory either. I have disassembled it a few times for some maintenance but I just find the sweet spot where I can flick it open and there’s no blade play then loctite the pivot. Some benchmades are a little harder ( like the shoki seriously ask me about this one sometime, it was a serious PITA ) but axis lock knives I find are pretty easy to adjust perfectly. I could be the exception but hey that’s fine with me I’m sure this new Ritter is a quality knife but I’ve no experience with hogue so I’ll stick with BMI'd be inclined more to believe you do not care about minimal side-to-side blade play (which again is great) than none of your Benchmade has any blade play.
I wish I could convey it through a video but mine has no up and down or side to side. It didn’t when it came from the factory either. I have disassembled it a few times for some maintenance but I just find the sweet spot where I can flick it open and there’s no blade play then loctite the pivot. Some benchmades are a little harder ( like the shoki) but axis lock knives I find are pretty easy to adjust perfectly. I could be the exception but hey that’s fine with me I’m sure this new Ritter is a quality knife but I’ve no experience with hogue so I’ll stick with BM
To be fair I’ve only bought 3 benchmades on eBay, a shoki, rift, and mini barrage, but all of those were the same as my grip. No play at all. Maybe I’ve just gotten extremely lucky but I’ve honestly had no QC issues and I’d call myself picky about that sort of thing with knives of this costI was/am not saying that every BM has side to side blade play. In your first post that I replied you said every BM you bought of ebay has perfectly fine QC. Anyway, I agree that Griptilian is a very well made folding knife. I have three (mini and full 20cv g10 version and the fill size gen 1 RSK Mk1) and all are perfect.
Had half a dozen 940's and never had any issues.
