You are right, the coating is semi smooth, I edited my original post.oddly enough, I was not expecting this one to be shorter than the 16.
liking the semi-smooth coat.
thanks for the pics!
Sometimes I think it looks good and others I think it looks odd. Maybe it’s both for me!Received my black BK18 from SMKW ... it was waiting on me when I got home tonight. I will have to snap a few pics soon. It looks good ... it's light in hand. I think I'm going to enjoy this one! I'll update that after I put it to use awhile.
3....? I am good jealous!!!! Happy for you!Ordered two black and one brown! Like these a lot. Can’t wait to try it out.
Nice sheath!
slightly wiggly grind near the top on this side, I think it will sharpen out eventuallynice semi smooth coating!Next to the 16. You can really tell that one is a drop point and the other sweeps up when you put them side by side. The 16 looks like it might even have a slight forward cant which I have never noticed before. Maybe it is an optical illusion.
Thanks. I’m going to take a comparison picture next to the bk15 as well that I will post later today.Awesome comparison photos..... Very helpful, their marketing depts. should of done That from the get go!
Thanks again!!!
Thanks again!!!
if you expand the picture you can see a little bit of the bk18s edge peeking from behind the 16. It is a little taller, but not as much i thought it would be. I actually envisioned the 18 having a longer blade than the 16 as well.StrangeDaze
Except now I'm confused at the "height of the blade" isn't it supposed to be taller than the 16? Not counting the harpoon part.....Your bottom photo looks like the edge is in the Same location for both???
Excellent.More pics, it looks like the 18 does have a slightly longer blade and also cutting edge. I also took more of the width difference that I believe shows the difference more accurately.
Even though the added width doesn’t completely clear my knuckles from the table, you can see in the photos it helps the blade come in contact with the cutting surface a lot sooner.
The bk18 on top of the bk15
new coating vs old
cutting edge comparisons
overall length comparison
I had the ends lined up as best as I could
doing the best I could to take some clearance pictures keeping my knuckles flat.
.Where each one makes contact with cutting surface
better width comparison with the bk16
I'm liking it, although I'm also likely to straighten the spine.
Thanks for those pics. Good comparison.More pics, it looks like the 18 does have a slightly longer blade and also cutting edge. I also took more of the width difference that I believe shows the difference more accurately.
new coating vs old
