I don't know if I would separate the heat treatment from the final hardness. There are better ways than others to get the same hardness so I would group them together.
I see hardness more as part of the result of the heat treatment. It is one measure of a steel’s properties so I wouldn’t break it out on its own. It’s almost like calling “corrosion resistance” one of the legs.
Your perspective on the issue is off I think. The problem with an m390 blade at a low hrc isn't that it's a bad knife or that it can no longer be used when it goes dull, it's that the end user paid a large premium for that m390 upgrade expecting an increase in performance that wasn't delivered.
A Ferrari with a 3 cylinder diesel engine will still get you where you need to go, but you're going to be pissed if you were expecting a 12 cylinder fire breather.
All blades will need maintenance. High end super steels should need less maintenance. A lot less. When it comes to this recent flood of m390, 20cv, 204p knives that hasn't been the case.
No one at all is suggesting to not maintain your tools.
1. Sharpening is removing material.
2. When you buy a knife, your cutting potential is basically determined by your behind the edge measurement, grind height, and stock thickness.
3. As you sharpen/remove material, you’re thickening the knife “behind the edge”, or slowly degrading it’s cutting efficiency.
4. The more frequently you have to sharpen in order to maintain a good apex, the faster your tool becomes less efficient. You’re also spending more time doing it.
5. In a perfect scenario, the end user has to spend less time, removing less material, to preserve the best cutting experience possible with the blade.
6. Well treated, properly hardened, appropriately selected steels, ground well, and maintained by removing as little material as possible to maintain a good apex -> where we want to be.
Yea you're changing the variable via grind and sharpening
I get it.
You don't
You're the one who thinks tools are magically losing edges
And overpaying for steel when you could just get the same 440c blade 10 times doesn't make any sense.
Just put a new one in your bag don't worry about the old ones grind.
As if you're ever gonna wear any of those blades away lol you have a dozen high end knives. None of those blades ever gonna change unless you're just over sharpening.
I like to treat these situations as opportunities to present clear points, so that observers can carefully consider what is being said by all involved parties, weigh the respective merits of the talking points, and benefit from the conversation. With that, thank you for your part in this exchange.
Had to remember how to block people. No idea why that might be relevant here.![]()
Ah, my mistake. Cheers!Like I said this is off topic, I was not* using my point to illustrate what HRC the m390 should be at.
Knives don't magically lose edges tho, that's not subjective. It's silly
And anyone saying it loses all credibility
Maintain your tools
I was again responding to the silly memes form the safe queen
Talking about ball bearings lol
You act like your folding knife is a surgeons scalpel
It's absurd
"hurrr let me drop some knowledge on you younging sharpening removes steeel"
Yea i see that by the steel that falls off the blade and collects on the table. Thanks
Pay attention to your tools. And don't have so many duplicates in the same niche you can keep track.
And I assure you you'll never "magically" lose an edge again.
Hi,Well explained. I think the adjustment might be a 3 legged stool analogy, where one leg is heat treatment, with a call out regarding desired results of heat treatment.
I'm starting to doubt that.Do you own a knife in M390?
Hi,
don't
don't sit on it, that stool analogy is falling apart/out
A better analogy is chocolate chip cookies / bread
Too much chocolate chip carbide and it wont hold shape
Too much carbon sugar, and its brittle
If you under bake 'em, they're play dough soft , low hrc
If you over bake 'em, they're brittle
After baking you gotta temper
Oil for drying rust resistance
世界一硬いパンの包丁はカーボンより硬い - sharpest Bread kitchen knife in the world - kiwami japan
