Gusbuster
- Aug 30, 2011
The Great White Sharks would disagree.I'm having sea lion for lunch!
Mmmmm The King of the Sea
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
They are like the T-Rex of the seaThe Great White Sharks would disagree.![]()
Orcas punk great whites routinelyThey are like the T-Rex of the sea
Orcas punk great whites routinely![]()
I've never understood the "psi" as it relates to bite force. Is this the force of the bite divided by the square inches of surface area of their teeth? Why is it a pounds per square inch unit. Why wouldn't it just be pounds? I bet I could develop a thousand psi of force with my pinky just using a syringe if the diameter of the plunger was small. That unit of measure, in a relation to bite force, has always been puzzling to me.
There's def a difference on the "tooth" or "bite" of a steel at the same grit finishAgree. Plus, they should specify the tooth, canine vs molar will make a huge difference.
normalisation per area allows apple to apple comparison. As you have said, animals will have different sizes of teeth and the same amount of force generated by two identical jaws will exert different pressure over a surface if the surface area of the teeth touching the receiving medium is different.I've never understood the "psi" as it relates to bite force. Is this the force of the bite divided by the square inches of surface area of their teeth? Why is it a pounds per square inch unit. Why wouldn't it just be pounds? I bet I could develop a thousand psi of force with my pinky just using a syringe if the diameter of the plunger was small. That unit of measure, in a relation to bite force, has always been puzzling to me.
Yeah, but what have you been doing for the dogs you incontinent, old bastard?
Maybe just the winter of your discontent.Is a 58+ (encroaching on 59) young-at-heart basid considered as an incontinent ol' bastid among you Gen Xers? Asking for a friend!
All day, every day and twice on Sunday.Is a 58+ (encroaching on 59) young-at-heart basid considered as an incontinent ol' bastid among you Gen Xers? Asking for a friend!
For instance, as you said you will require a very small amount of force to generate a large amount of pressure on a surface with a small needle. On the other hand, in order to generate a similar pressure on the surface with a larger surface, lets say a 5/16 inch rod, you will require a much higher force but the resultant pressure on the surface will be the same. So, if you only judge by the amount of pressure generated on the surface you will miss that actually a lot more force is required to create a similar pressure on the surface with a 5/16 rod.
