You should tagOK FortyTwo, care to give us a bit of info as to what and when? There's a term (usually reserved for females) for people who do what you did.Armadew, Yes, yes it is.
Yeah that's right, they're too thick. Some of these things are as thick as a damn hatchet! They're all twice as thick as they need to be. Every damn one of 'em. A little bit of flexibility from being thinner could be considered a strength under shock loads, you know.
And what's with the obtuse Degrees Per Side edge angles? 20-25 dps? That's like a 45 degree included angle. That's like the corner of a box. It's not supposed to be a splitting maul.
They all need to be thinner. And sharper!![]()
Very nice. I love a hand polished blade. I’ve done it several times and it’s a labor of love, to be sure.So , you like it thin ......behind edge of courseI hope you will like this two ......
First one is 3mm on spine and grind to zero , HSS M35 and 67 HRC .This one still unfinished is same steel same grind and 2mm on spine .Booth will cut off balls on mosquito and he will not feel it
And I was stupid enough to try to hand polish this thing
OK FortyTwo, care to give us a bit of info as to what and when? Sounds interesting.Armadew, Yes, yes it is.
its y'all. come on you're from the south.....sort of anyways.
if it cuts, I don't care so much about angles. my biggest beef with makers isnt thicker blades and edges, it's not getting somewhat even bevels and edges. I really dislike having to reprofile and even out brand new knives......so they can be easily touched up.
I reground 4 blades from Queen.Even my Queen D2 slipjoint was too thick at the edge.....a regrind does wonders though.
Mecha -- I think you'll like a model I'll have coming out soon. It's a tough little 3" bladed utility fixed blade with a THIN grind. Made to be sturdy enough for hard use by folks who know how to walk the line of what a tool's able to reasonably handle while retaining an efficient cutting geometry.
The blade is chosen based on the tasks it will be used for which run from slicing paper to chopping wood to preparing meals and possibly self defense. And don't forget display and admiration.
There are many knives that fit that last category that are thick with sculpted grinds and fancy materials and finishes that are not meant to be used.
Everyone gets to decide what use they want to cover and what knife they choose. Fortunately, this is the golden age of knives and there are plenty to choose from.
I think what he means is use the right tool for the job. Don't go chopping trees with straight razors and slicing tomatoes with a froe. Even if the edge is thin, use some common sense and KNOW that your edge is thin, so task the job appropriately.
What term are you talking about that's "reserved" for females? Are you being derogatory?
Katanas is calling 42 a "tease," which I'd say is accurate for his sword thread which was a total tease-a-thon.
Very few knives I enjoy cutting with more than the Police4
The Police4 is definitely the better slicer with thinner blade stock, and possibly thinner behind the edge.Nice! I have been thinking about picking up a Police 4. How does it compare to Military in terms of slicing ability? I read somewhere that ergo goes slightly to Military.
