WHAT HAS SCIENCE DONE?!
I came up with another way to use jigsaw blades with a swiss army knife. This will work on any 91mm model with a bottle opener. It only requires a small modification to the bottle opener. What follows is quick and dirty run through of how to do this.
You don't actually need to take your swiss army knife apart in order to do this. That's just how I made my example pictures.
We start by drawing with a permanent marker on the spot where the top of jigsaw blade will meet with the inside of the bottle opener.
Next we cut a small notch into that spot. The bottle opener isn't made of hardened steel like a knife, so I just used this cheap Lenox hacksaw to make the notch. The hacksaw handle was around 8 dollars and it came with the hacksaw blade for free.
My notch looks a bit rough, but I'm sure that you could do a better job with the proper tools.
Here you can see how the jigsaw blade fits into the bottle opener.
The fit is tight enough that it doesn't fall out when I pick it up. I can even shake it up and down and it won't come loose.
Now we need to stabilize it. You could use pretty much anything for this. For this example, I used two hard plastic scales from a kershaw mini prybar. This way I didn't have to spend time making anything.
The plastic scales are screwed together around the jigsaw to keep it from twisting itself out of the bottle opener while sawing.
That's it. You can do this small modification to any 91mm SAK with a bottle opener. Good examples would be a 2 layer Spartan or a 2 layer Tinker. The modification is just to the bottle opener itself, and so you don't need to take the SAK apart in order to do it.
This might also work on a 93mm alox model's bottle opener, but I don't have any to check it with. I don't really know if it would work on the smaller 84mm model bottle openers either.
edit: okay, I have some slight adjustments to this little mod!
What wasn't immediately obvious (to me) is that different t-shank blades can have slight differences in the contours of their shanks when compared side-by-side. I didn't notice those differences until I started to test this mod with some other jigsaw blades.
I had to slightly enlarge the notch on the cap lifter with a diamond and ceramic file so that different jigsaw blades could fit. As a result, the jigsaw blades wouldn't always fit tightly anymore, and would tend to slip out of position while sawing. This is obviously not good, but thankfully there is a solution.
All you need to do is just make your stabilizing piece so that it fits snugly against the top of the bottle opener and the bottom of the t-shank. This prevents the top of the t-shank from being able to slip out of the notch in the bottle cap lifter.
To demonstrate this, I've wedged a pair of tweezers between the top screws of the stabilizer and the top edge of the cap lifter. The tweezers take up the extra space between the screws and the top edge of the cap lifter, which stops everything from being able to slide down.
I hope that makes sense.
This is all still new. I just thought of this mod today, I built a proof of concept in under an hour, and I shared the photos/instructions immediately afterwards. So that's the main reason it is so rough around the edges. Maybe I should've spent more time working on it first, but this is what ya' get.
I may or may not post additional updates/refinements to this later. We'll see.
edit2:
On to the next phase...
Yes it's very ugly, but it's sill only a prototype. We now have a longer sturdier metal stabilizer piece. It is made from 2 aluminum side plates which are being held together by 6 screws.
6 screws seems like a lot to mess with. If I can, I'd like to figure out a way to reduce that number.
Here is a look at the inside:
The screws are of course strategically placed to hold everything together as solidly as possible. Of particular noteworthiness is the screw passing through the wire stripper.
The goal is eventually to settle on a design that can be easily put on and off using only your fingers. Maybe something with thumb screws and wingnuts. I'm not really sure yet. I want the stabilizer piece to be easy to build and simple to use, so I feel like I might not currently be on the right track with it.
edit3: it still seems to still work fine with only the 4 outside screws
So now we've gone from 6 screws back down to 4 again. I suppose that's progress.
I have another idea for a different way to make the stabilizer... It should be simpler, but I don't know how well it is going to work yet, so I'll just keep it to myself for now...
