- Nov 25, 2006
Ok, but it's no longer Cold Steel. It's now "Bean Counter" steel.
4034 as treated by Cold Steel is within 17% of the edge holding of an average factory blade with AUS-8 or 440C.
Cold Steel knows their stuff.
Cold Steel has always sold knives in 420HC and similar, I still have a 420HC Oyabun (9" blade) from 20 years ago and I've happily beat the crap out of it this whole time.
People need to actually look at steel performance before they talk about what kind of steel is best for a given knife: https://knifesteelnerds.com/2020/05/01/testing-the-edge-retention-of-48-knife-steels/
1095 and O1 have the same toughness as S35VN, everyone clamouring for "the good old days" with basic high carbon steel in these big knives are actually just looking at everything through nostalgia glasses.
If we really want to see things improved we should tell GSM to change from 4034SS to AEB-L or 12C27, at 60RC AEB-L is still tougher than 3V, the knives will hold an edge slightly better than 4034SS and overall it's still about 4X tougher than the average basic high carbon steel.
With informed constructive feedback it's entirely possible that GSM will be able to manage Cold Steel better than Lynn Thompson did.
But if all they see on the forums is raging mobs saying they hate everything then the only logical conclusion is to ignore everyone.
Some knives live in pockets. The emerge every now and then to cut some string or open a package or perhaps, in extreme cases, to process some game animal. That is their intended purpose at any rate. In a knife like this the steel really doesn't matter. Any steel, including the infamous "surgical stainless" will do fine. Just sharpen when it gets dull and it will last lifetimes. Worst case, it takes longer to open your mail.
Other knives live more adventurous lives. They chop and baton, they are hammered through ration cans or used to dig trenches. They might even get stabbed through a car door or be called on to defend the life of their owner.
Knives like this are a tool, and if they fail in the field there is no easy way to replace them and the consequences might be dire.
If I wanted to take up mountaineering I wouldn't buy my rope from Walmart. Nor, I suspect, would anyone here. We all correctly conclude that it is probably crap. In the case of this steel, to the best of my knowledge,with the exception of people employed or sponsored by GSM, every single expert in the industry are all unanimous in their conclusion about 4034. They are all saying the same thing, that it is extremely cheap and not particularly good.
It is possible that none of these people have even tried to really see what it could do when modern science gets after it. It is possible that it has qualities no one outside Lynn Thompson ever suspected. Perhaps you can trust it the way you would 3V, or A2, or S35vn. Perhaps. But someone is gonna need to actually prove it.
And even if this were true and GSM really had discovered some metallurgical magic, the metal remains what it is, a cheap steel that costs a fraction of what the established hard use steels typically cost. GSM wants super-steel prices for liner-steel knives.
I noticing a theme here. You keep saying 4034 is tough and ideal for large knives. of course its tough, its hardened to 54-55 HRC. That's soft. No, not compared to much older blades, which definitely worked as designed, but compared to what we expect today. In a sword its perfect, I guess. Its harder to damage than a higher carbon blade at 58. But, and this is a big but (cause I like them and I can't deny...), we want a harder edge, a longer lasting edge.Where you've got this all wrong is assuming that cheap steel is bad, and this is exactly the backward thinking that needs to be put to rest in this conversation.
Today the millions of miles of railroad tracks lining the continent are higher quality steel than the best Japanese Katana from 200 years ago.
The most basic steel produced by modern metallurgy is practically magic compared to the best steel people knew how to make only a few generations ago.
Similarly, 12C27, the steel type I referenced as being "the" ideal stainless steel for large blades, is commonly employed in disposable razors.
Yes, your disposable shaver uses the highest quality and toughest stainless steel in history.
Any time anyone talks trash about 4034SS because of its "price" they are reinforcing a culture of willful ignorance and causing active harm to the legitimacy of this forum.
If you want knife makers and manufacturers to continue dismissing consumers as dumb sheep then by all means believe whatever you want and keep promoting the magical properties of whatever steel is on your favorite knife.
If you want knifemakers and knife enthusiasts to be able to have intelligible conversations then you'd better start using materials DATA in any point you want to make about any knife from here on.
Source?I noticing a theme here. You keep saying 4034 is tough and ideal for large knives. of course its tough, its hardened to 54-55 HRC.
"You" want irrational things, not what most people want and not what makes the best product.1.4034 has been around since like 1947 and doesn't seem very popular in making knives. According to Larrin , it may have been somewhere in the family tree leading to the development of steels like 13C27 and AEB-L, which are both widely used in knife blades. Even those "improvements" on steels like 4034, have been improved upon by even a cheap steel like 14C28n. On a knife like the Gurkha, I want a strong and lasting edge (within reason and balanced with "toughness").
Enthusiasts say they want carbon steel, but sales numbers say you are in the minority and most people care quite deeply about rust resistance.So, I'll never like 1.4034 as much as you do, though it would work fine for most of my use. Ill give it to you that a big, tough (and quite stainless!) knife can be fashioned from it and be very functional. But, does it have a very good balance of properties for a strong and hard blade, which resists breakage and holds a good edge? Most would likely say NO. SK5 works very well, but isn't SS, of course. The crux of this complaint is that CS made better all around big blades in SK-5 for cheaper. CS made better largish blades in Aus8A.
No one anywhere ever has agued that these knives are not overpriced, you're fighting with windmills.I've read AEB-L makes great big SS blades, maybe 14C28n would be even better! If CS sold a 4034 Trailmaster for $30 like MTech, it would sell like hotcakes. That's what everyone here is saying.
At competitive prices, perfectly suited for the application.Another is is that CS is making pocket knives in it as well.
One never knows when they’ll need to drop $10 on a Cold Steel gas station knife to scrape bubble gum off their sole.……At competitive prices, perfectly suited for the application.
8Cr13MoV is far from something you want to brag about, and calling something 17% as GOOD is something I never wanted to see on Cold Steel thread...Again, in practice we know it holds an edge to within 17% of the standards of Spyderco 8Cr13MoV, so no matter what has been done to it, this steel is competitive with the most reputable competing manufacturers.
And yes Cold Steel is still sourcing German steel, not Chinese steel, so you know that this is coming from a highly reputable foundry and is definitely NOT the cheapest steel on the market.
I can smell cope... cope is strong with this one.As much as AEB-L will be better at some things, it's still a trade off of attributes and when we know 4034SS does hold an edge so similarly to the common higher carbon steel types I can't argue Lynn made the wrong choice using the lower alloy steel.
4034SS is one of the best steel types in a large blade, which is exactly where Lynn chose to deploy it.
Kukri is one of those knives that should never be in 4034"You" want irrational things, not what most people want and not what makes the best product.
Genuine Himalayan Imports Khukuris use basic carbon steel with a differential temper that varies from the mid to low 50's RC range, of all the knives that have moved to 4034SS the Khukuri is the knife that should never be moved off of 4034SS unless they're going to start using 1055.
Sure... 4034 is selling like hot cakes, oh wait - it doesn't...Enthusiasts say they want carbon steel, but sales numbers say you are in the minority and most people care quite deeply about rust resistance.
Making large blades out of AUS-8 is arguably a mistake.
So you want to say that you agree that 4034 is cheap, doesn't perform in it's price range and is not worth it at these prices?No one anywhere ever has agued that these knives are not overpriced, you're fighting with windmills.
Fixed it for you.At competitive prices, could be acceptable for the application.
Yepp, lots of people would definitely give 10€ for a 4034 folder with triad lock.One never knows when they’ll need to drop $10 on a Cold Steel gas station knife to scrape bubble gum off their sole.
Why 4034? Just call it Surgical Stainless.
n2s
Like I was saying, 4034SS is a well known steel from a reputable foundry, you don't see anyone complaining about the wide selection of knives in Buck 420HC, or Victorinox 1.4110, complaining about the same type of steel when used by any other brand is just hypocrisy.One never knows when they’ll need to drop $10 on a Cold Steel gas station knife to scrape bubble gum off their sole.
n2s
420HC and 4110 are actually step up. 420HC has some Vanadium, Manganese, and Silicon... 4034 does not...Like I was saying, 4034SS is a well known steel from a reputable foundry, you don't see anyone complaining about the wide selection of knives in Buck 420HC, or Victorinox 1.4110, complaining about the same type of steel when used by any other brand is just hypocrisy.
Too much talk, too little show. I waiting too see these marvelous new knives tested against their Mtech clones to see if there is there is anything there to justify the 1000% price difference demanded by Cold Steel.Like I was saying, 4034SS is a well known steel from a reputable foundry, you don't see anyone complaining about the wide selection of knives in Buck 420HC, or Victorinox 1.4110, complaining about the same type of steel when used by any other brand is just hypocrisy.
How would you know where Cold Steel is getting their metal from? Real Aus8 comes from Japan, and ONLY from Japan. Yet we know from Andrew Demko that their manufacturers in Taiwan regularly pushed low grade and price Chinese Aus8 as a cheap alternative. We know that so.ething similar happened with Cold Steel's efforts with A2 -- they simply could not get it at the quality level they wanted. I think we can assume that this is true of every other steel as well.Source?
You can't throw around outrageous statements like that without proof.
Quite frankly asking for anything better than this is almost splitting hairs, only difference between AEB-L and 4034SS is around 0.15% Carbon:
Possibly the same as the price of 3V SRK, Recon, Warcrafts and AK-47 going down...Another question for the group. S35vn / G10 AD10s and SR1 have come down in price pretty significantly from where they were a couple years ago. How? What changed?
AG Russel Knife Steel ChartSource?
That will not be a difficult battle to win.Too much talk, too little show. I waiting too see these marvelous new knives tested against their Mtech clones to see if there is there is anything there to justify the 1000% price difference demanded by Cold Steel.
We can then compare them to the traditional Cold Steel product; but, there is no need to go there if they prove inferior to their own clones.
n2s
thought 13c26 was the disposable razor common steel?Where you've got this all wrong is assuming that cheap steel is bad, and this is exactly the backward thinking that needs to be put to rest in this conversation.
If you want knife makers and manufacturers to continue dismissing consumers as sheep then by all means believe whatever you want and keep promoting the magical properties of whatever steel is on your favorite knife.
