- Mar 8, 2008
Thanks for not minding.
Back to the subject, the only laminated blades I have are the Spydercos Diemaker mentions, and an older mora.
Haven't used or sharpened the mora much, but the Spydercos have been thinned, sharpened, and reshaped a lot.
I've used diamond plates, diamond bonds, Norton crysolons and their aluminum oxide stones, cheap ace hardware aluminum oxides, and spyderco sintered ceramic without any issues, other than aluminum oxide not cutting very well.
I guess I don't really understand the concern, is there something different between other makers laminated steels and Spydercos when it comes to type of abrasives used?
I believe the cause for concern over abrasive type is probably derived chiefly from Japanese laminated culinary knives, which are often run in a glassy-brittle hardness range at very low angles, which makes them very sensitive to lateral pressure, and can result in chipping if excessive pressure occurs as a side load, as it may when sharpening.
