David Martin
Moderator
- Apr 7, 2008
I've heard that. I have the wood glue and a couple of 'C' clamps. I' ll see. DM
What a bummer.Ok this is the haft I put on in July 'this year'. I may have split a little more that 12 rounds with it. Today splitting the round it's laying on it bit the dust. I have not over struck with it. So much for giving it special mounting treatment. It lasted less than 5 months use. Close to normal for my Emory oak. DM
I'm glad to see for you also the handle is an expendable and replaceable element. How much evil gets perpetrated on the Axe in the effort to avoid this recognition. I'm just wondering what this curing you mention entails. Why cured makes better splitting vs fresh.Plus these 6 rounds were not cured. So, I will allow them more curing time.
David how long is the bottom of the eye on your council axe there? Exactly 2-1/2"?Josh, that is the manner I hung it.
Square, that maybe what I have to do. Plus these 6 rounds were not cured. So, I will allow them more curing time. The wood I have is hard & tough and no ax handle can take the pounding. Other than my metal handle and it doesn't have the weight to get the job done. So, saw cuts, wedges & a sledge will be the order of the day.
If I just cut juniper, spruce or pine, all my ax handles would last and there would be no problem. DM
This seems like a sensible proposition - axe handle wood choice determined by the conditions of its use rather than the dogma of one choice fits all.David how long is the bottom of the eye on your council axe there? Exactly 2-1/2"?
I'd like to find you a piece of hop hornbeam. If you break that, you'll be breaking a record I think! Both of the woodsmen that I know and respect the most swear by hop hornbeam as the toughest wood they've ever come across for an axe handle. And won't go into the woods with anything else.
I think your Emory oak would be the perfect chance to see how tough it really is!
If that's something you'd like to try, I'll undertake the task of trying to find you a piece. Might be that 32" is the longest I can find though. And I'd need to know that bottom measurement so I can make sure it'll have a large enough tongue. Just let me know! It'll take me awhile to find it. They don't grow large or straight very often.
Ernest, when splitting Emory oak, (a round prior to the photo & the rounds on Monday) the non cured wood. At hits the axe will bounce off for the first 8 strikes. 4 on one side, roll it around and 4 on the other side. Until I can get A crack developed. Then it starts sticking. Whereas 5-6 mos. of curing the ax will stick on the first strike. Oaks cut in E. TX. the ax sticks on the first strike. Once you get it out a wedge can be driven and it doesn't bounce out. DMI'm glad to see for you also the handle is an expendable and replaceable element. How much evil gets perpetrated on the Axe in the effort to avoid this recognition. I'm just wondering what this curing you mention entails. Why cured makes better splitting vs fresh.
Josh, this ax head top to bottom at the eye is 3 5/8". The eye width is 2 3/8" at top.David how long is the bottom of the eye on your council axe there? Exactly 2-1/2"?
I believe, it was supposed to be concave/hollow grind not convex.Ok, I have been going at it with a sharp wedge, set convex. Which does just bounce off. Still, I'll let it cure before the next try. Thanks, DM
a trick to have more firewood! well done!Ok this is the haft I put on in July 'this year'. I may have split a little more that 12 rounds with it. Today splitting the round it's laying on it bit the dust. I have not over struck with it. So much for giving it special mounting treatment. It lasted less than 5 months use. Close to normal for my Emory oak. DM
Sorry David, I meant the length of the eye, front to back. I consider the other measurement the height. Lol. Should be 2-1/2" but it may be a little over. I just wanted to know because I like having the eye full. Figured you do too. And if all I can get is a 32" can you still split with that?Josh, this ax head top to bottom at the eye is 3 5/8". The eye width is 2 3/8" at top.
To me any haft costing over 40$ then mount and slam it around is getting pricey. My axes are working tools. Not for hanging on a wall. Just stating the truth. DM
