- Dec 30, 2000
Do you ever run outside, smiling ear to eat and hug your mail person? Haha.
I would, but they usually come when I'm either not here, not able to go outside, or I don't hear them.
So you wouldn't make for a very good guard dog then.I would, but they usually come when I'm either not here, not able to go outside, or I don't hear them.
Glad YOU said it. Lol.When talking about censorship,
Take a gander sometimes at the political thread here.
It seems the most active folks posting opinions are the moderators.
And it aint always pretty.
That will give you some perspective of how things are judged around here.
Untitled by GaryWGraley, on Flickr
Untitled by GaryWGraley, on FlickrThe added benefit to what you did is, you covered the bottom of the snap. Now it can't wear on your pretty wood scale.A small piece of deer skin, very soft, it will act like a cushion around the knife so it snugs up the fit. about 3" by 2" section. Since the piece of leather isn't being glued up for strength, you don't have to do the usual contact cement process of putting glue on each part and wait until tacky. That would make it pretty difficult to get the piece in there if you tried that, much bad words would be spoken if you did
So just apply contact cement, I use Weldwood from walmart, onto the back of the deer skin, and the using some popsicle sticks insert it into the sheath and I use that metal ruler to push the skin into position and make sure there were no sections that folded up under themselves, use a light so you can make sure it's flat and smooth around the inside of the sheath.
So now if the flap comes undone, there is far less chance that the knife could bounce out, where before I believe that could happen too easily.
G2
Has happened to me before. Knife just showed up one day.
I wondered, because I wanted to get one of the distressed brown 112 sheaths for my old 422. They're the same size as the 112.....I think.Ironbut , dunno about anyone else but it was far too loose, the knife would fall out easily just handling it on the table when the flap was open. Just a little too loose, the leather I added does protect against the inside part of the snap and as the leather goes from one side to the other, the knife will press against the sides which also draws the front in slightly so now it has a bit more retention on the knife, mucho bettero.
G2
So you wouldn't make for a very good guard dog then.![]()
I just checked the USPS tracking and they finally updated (the only previous entry was the label print on 15JAN24). The tracking info shows delivery today by 21:00.
We shall see, USPSA . . . we shall see.
If you all hear screaming and maniacal laughter later today, that will mean the package arrived. If you hear weeping and sobbing after that, it means that I decided to be a good person for once and give the 112 to my brother.
I received my 112s today. I'm a little disappointed in the boxes. I like to keep the boxes for all my knives. For both knives, I had to cut off the cardboard sleeve around the box. The sleeve would not slide off. Yeah, I know it's just a sleeve but none of my other knives are like that. I wonder if they made a box/sleeve change?
My 112 sleeve was extra tight also. Didn't have to cut it off, but it was noticeable.
I've cut off 5 or 6 of the sleeves..I really really tried on one to keep it perfect but after 20 minutes of struggle gave up. I have also never ever seen a 112 shieth that loose/big!! If I get one like that I'll pair it with a fat Stag 112 I have that barley, just barely, fits the shieth it came with. My 2 should be here Tuesday..
