True Story 3/22/2017: I handed the customer 3 bananas off the 5 banana bunch and put them in the old woman's shopping cart, trying to make it seem as if I hadn't just rammed the point of my CS recon mini tanto blade into my index finger. We talked for about half a minute more. Right before we parted I checked her three bananas hoping no blood had gotten on them. There was a little spot of blood on one, not a full drop, so I wiped it away with my other hand. The red sort of went away and I said yep, this a good one. About twenty minutes later it stopped bleeding.
OK I will tell you why I won't buy another tanto blade. The top of the blade is longer than the bottom of the blade so it can be difficult in some situations to judge where that point is, and the cutting surface is flat so a tanto blade is like cutting with a razor blade. I've never found a good use for the vertical edge. Based on what is known from history, the tanto shape was used to puncture whatever you were trying to kill, esp when you needed to go through someone's armor. I learned tonight that it does excel in that area.
Coldsteel knives are hardcore, that thick Carpenter tool steel is extremely powerful and should not be taken lightly. It makes a VG-10 spyderco look like a child's play thing. I think for now on I'll carry the spyderco since its lighter and easier to handle, and save the cold steel for when that kind of power is truly needed.
