Grenock
Platinum Member
- Apr 7, 2016
Hey E, remember this one?Is that why you sold it before it shipped?
……… have it in your possession……..
#NotNinJoJo, can you please shed some light on why Antique Micarta isn't being offered on at least the Signature Series SDFK (I understand not offering on the basic series). Are you near the end of your supply? Is there a minimum number of scales that need to be made for each run of each color? Thanks for the info! Was really hoping for this option, as I am sure a lot of others were as well.![]()
#NotNinJo
The HDF scales are interchangeable with the SDFK.
… but no lanyard cutout if it’s like FK2/BFK.#NotNinJo
Yeah the HDFK scales will have a useless little but hole when used on the SDFK.… but no lanyard cutout if it’s like FK2/BFK.
#NotNinJo
That's what heat guns are for. A few seconds waving it around the opening of a kydex sheath will help with fitment. I've done it on several kydex holsters to accommodate minor changes.Somewhat interchangeable.. your kydex sheath may or may not work, I think Nathan stated as much in Post #293 of the SDFK thread..
I guess that would work to tighten up the kydex as the HDFK steel is thicker and the scales are probably the same thickness between the two knives.That's what heat guns are for. A few seconds waving it around the opening of a kydex sheath will help with fitment. I've done it on several kydex holsters to accommodate minor changes.
I didn't read the earlier posts, so I was just making a general remark about fitment with guns and kydex holsters. I had to adjust a few to allow some modifications to fit.I guess that would work to tighten up the kydex as the HDFK steel is thicker and the scales are probably the same thickness between the two knives.
With as few as we were making, it just didn't seem necessary and because this is kind of a small chopper I thought the TeroTuf would be practical.Jo, can you please shed some light on why Antique Micarta isn't being offered on at least the Signature Series SDFK (I understand not offering on the basic series). Are you near the end of your supply? Is there a minimum number of scales that need to be made for each run of each color? Thanks for the info! Was really hoping for this option, as I am sure a lot of others were as well.![]()
No, Nathan has decided he likes the new Drop Loop better.Another SDFK question...
Are HDFK style dangler sheaths an option?
Scales choices for the SDFK are:
Canvas micartas
Black
Natural
Double Black
Double Red and
OD Green
Linen micarta
Red and Black
Natural Burlap micarta
Gray TeroTuf
OD Green Terotuf
They do NOT have the undercut, but they do fit the HDFK and the HDFK sheath.
Jo
I just had to look it up tooCan someone point me to where I can see a close up of each of these scale colors in all of their glory? Really interested in good photos of the Double Red and Double Black.
Edit: Nevermind, found in the Encyclopedia
Hi Darren,Hi Jo.
Thanks for posting the scale choices for the SDFK.
On another note, can you please describe the process and grits used for polishing the scale screws for CPK's? I'd like to do some DIY polishing on my inventory.
