I believe that’s Mjolnir. If I’m not mistaken Nathan has some contracts with the Asgardian military. Thor leaves Mjolnir once in a while for Nathan to clean it up and Nathan usually shoots his videos that week. Some or all of this may be incorrect.Nathan the Machinist - forgive the maybe silly question, but I wondered:
In your videos (e.g., on the BFK) you use a hammer to drive knives into nails, concrete, etc. What kind of hammer is that and how do the knife spines look like afterwards ?
Roland.
#notnathan
I treat all rust on blades with this method. Especially, for under the scales.
A rag and mineral oil. It will remove all the loose red rust, and change the red rust to black rust. Black rust is extremely slow moving compared to red rust.
For cleaning anything and everything from my blades I use hot water and dish soap followed by mineral oil on a rag.
I usually keep a mineral oil soaked rag in a ziplock at work and when hiking.
#notnathan
Yeah.I've bought 5 CPK knives so far and have not seen any rust on any of them - not one speck. I use Renaissance wax under the scales and Break Free CLP on the rest of the blade.
Well, six knives, but I haven't received my grandsons UF2 yet.
G Ghost coyoteNathan the Machinist
I removed the scales of my dek and found rust, I used barkeeper friend to remove it but it stained the blade, do you know how could clean it up?
Count me in on an answer to this question.Nathan the Machinist
Hi Nathan,
I have a couple of questions for whenever you have time to answer them. On the DEK3 the description states,“The swedge does not come all the way to the point to prevent the tip from being overly fragile,” would you recommend not adding the sharpened tip for the same reason?
The computer rendering of what the DEK2 “won’t look like” has a Tanto like blade shape, will the DEK2 have a similar shape with an extremely strong Tanto point?
Thanks for all the wonderful options!
Nathan the Machinist Congratulations on putting out the pre-order. It is a nice one and offers plenty of options for people to choose from. The amount of time, effort and planning that has gone to it is obvious. And of course, credits to Lorien for his contributions to the design. I have a few questions (if I may ).
1-) Is your HT protocol ready for MagnaCut of will it get evolve until you start production? Your initial impression does not align with the data we see from others (i.e. MagnaCut being stainless 4V) which is not a problem. That is what we need to really understand something. But how far is MagnaCut from 4V as it is, and how much improvement can we expect in the coming 18 months (or whenever you start MagnaCut production)?
2-) Do you have D3V vs MagnaCut like by like comparison? When I say like by like I mean both at the same hardness, preferably harder than 62. The current understanding of 3V is toughness gets reduced disproportionately when the hardness pass 60, so I am wondering in terms of edge stability (I see that combination of hardness and impact toughness), what will be the difference between the two steels if hardness set to 62 for both?
3-) What would be the behind edge thickness of DEK2 and DEK3?
4-) Is ordering without a sheat an option?
5-) Shall we expect to see drops and Friday sales of DEK2/3 for the next 18 months or are these patterns exclusive to the pre-order?
Yeah.
For knives that I know will be exposed to moisture/the elements with minimal maintenance (like my MC), just for my own piece of mind, I removed the scales when I first received it, coated the handle with a wax type protectant and allowed it to fully dry before replacing the Terotuf scales.
If I do something like this on any CPKs in the future, I'm going to spray the bare tang with Plasticoat and let that dry before replacing the scales til the end of time (Personally, I'm not one to continually/periodically change handle scales. The only times I've had more than one set of scales for a CPK, was to decide which I preferred. Once that's done, it's done).
