- Jul 31, 2015
Hollow grinds don't really "wedge" in most mediums... While in cardboard they are not at their best, thick cardboard being a tricky material, they still don't "wedge" all that severely even in that, although you have to be careful of the occasional acceleration...: A comparably thick convex would be a little more predictable, but that would be about it.
As for burying itself in thick materials while chopping deep into wood, the effect of the Hollow Grind's "wedging" action is beneficial if the Sabre Hollow Grind is set low enough and the blade is heavy and thick enough: The "wedging" sends wood chips flying just like a thick axe, but with the added versatility of fine cutting... In fact for chopping wood, most Sabre Hollow Grinds are not heavy enough and sabre ground low enough to get that benefit...
Overlooked is that, over decades of wear, hollow grinds stay the exact same thickness at the edge, while all other grinds lose geometry acuteness and thicken behind the edge on every single sharpening: Other grinds need really wide blades, or really wafer thin edges, to minimize this geometry change over time...
I suppose you are only talking about folders here, but if you include in this fixed blades, then I can only say you have got to be kidding...
Look at the factory fixed blade makers that offer mostly, or almost exclusively, convex or flat grinds: Blackjack, old and new, Fallkniven, Bark River, Busse, Esee, TOPS, Ontario, most large non-Tanto Cold Steels, and a slew of others I forget...
About the only notable exception in "newer makers" is SOG...
Now look at factory makers that offer almost exclusively hollow grinds on their fixed blades: Buck, Randall.
Current popularity? No doubt about it: Hollow Grinds are just the latest flash in the pan...
Gaston
My apologies, I did indeed mean 'folding' knives.
