I think this is absolutely true.I think he summed it up nicely in the very beginning by saying what tolerances were and noting that what the average person means by "tight tolerances" is the perceivable result of good tolerances. In that way, I think the average person is using the term correctly because the perceived result is what matters to most people. Practically no one will know the actual numerical tolerances in the materials, sometimes not even the maker.
Squarely in the realm of perfection!So where does this leave zero tolerance knives?
Technically tight tolerances may have a definition, but it's up to the user to decide what they're satisfied with.
Only made it about halfway through it..Will finish it later as I have time.
I will mention that he talks about calipers being able to measure .0005in.
There is a difference between resolution and measurement capability.
.002 is what the manufacturer of those calipers has listed. Most people that have used them for a decent amount of time are able to measure .001 accurately.
Otherwise, what I have seen looks pretty good..Will finish it a bit later though.
I prefer accuracy to precision.Yup. Precision vs accuracy.
Tolerances are a deviation from a mean. The tighter the tolerance, the closer to the mean you are, which is where you want to be. Repeatably preferably... This to me, in knife terms, is a tighter lockup, smoother action, and perfect fit/finishes.
