I got a Spartan Blades Enyo Elite Gold Class, S35VN, a few years ago. It was quite dull out of the box, over BESS 600 near the tip. At that time, I had the older Work Sharp Precision Adjust. I tried and failed to get a burr on the Enyo. I think I spent about half an hour and gave up. Never got a clear idea of the angle using the marker method.
Then I got a laser goniometer and discovered the edge bevel was 28 DPS about midway between tip and heel. It's hard to use the laser near either end. But 28 DPS? WTF??
Later, I got a TSProf Kadet with the TSProf diamond stones down to 150 grit. I reprofiled a Lil Native S90V from 18 to 15 DPS pretty easily. So I had another got at the Enyo, aiming for 20 DPS. Finally got a burr near the middle of the blade, but very little progress at either end. Put it away again.
A new Work Sharp Professional Precision Adjust barely did anything to the Enyo, but the stones go down to only 220 grit.
Then I got a Hapstone R2/V8 with Hapstone CBN stones down to 50 grit. The 120 grit had little effect on the Enyo, but after more than an hour, I got a burr about an inch long along the edge using the 50 grit. But progress was still very slowly at either end of the blade.
I read on this forum about the Poltava CBN 120 grit. Spent half an hour with the Poltava 120 and finally got a burr all along most of one side. But I was stuck for a long time with the edge as shown in this photo below of the half inch of the blade nearest the tip. (Sorry, my stupid phone is lousy at photographing knife blades.) The black stuff is just filings. The important thing is that bright, shiny strip right along the apex that the stones have not touched yet. I got out the new, expensive laser goniometer. After a lot of fiddling, I finally got a reading of 35 degrees on that shiny strip.
Next I got a Poltava CBN 60/80 grit. Half an hour later, the shiny strip was gone, and there was a burr along the whole edge. Another half hour with the Poltava 60/80 and I had a burr on the other side. Another half hour going through the finer stones and I got BESS scores in the 160 to 180 range.
The Poltavas seem to cut quite a bit faster than the Hapstones of similar grits.
