Oh I've been around. Doing ok. I recently found this thread and started rereading it. And now darnit I am buying a few more Barlows just because. Trying not to venture too far afield from the affordable user common brands but darnit again, even sticking to mostly Schrade and Camillus that leaves a bunch of patterns before you get to commems and special editions. Or Ulsters.Hiya Codger!! Nice to see you putting a word in!!
How ya been?? Where ya been!!
Charlie
Codger_64 I would this this with a grain of salt but was informed by the seller that the "Boulder col" tang stamp was used from 1935 to 1950. I have no way to confirmNeat! I have one like it too. The mark side is stamped "WESTERN" over "BOULDER COLO" over Made in U.S.A.". The pile side of the pocket blade is stamped"822". Any idea of production era? I assume that the scales are Delrin so 1961 or later. Odd that the linings are steel.
You've probably seen this, but in case you haven't...Codger_64 I would this this with a grain of salt but was informed by the seller that the "Boulder col" tang stamp was used from 1935 to 1950. I have no way to confirm
I did get your message my friend , but I have been outside and off the air virtually all day . Thank you very much my friend .Harry, if you contact @Rockon75 (Josh) or me, you can have ANOTHER knife in your pocket!!
Charlie (I can't leave you a message!!)
@mkbr much appreciate your post! That sheds a lot of light!!!You've probably seen this, but in case you haven't...
I can't vouch for its veracity. I believe I got it from a thread over at AAPK. Western tang stamps.
Hats off for your help! Knowing the history helps but bought it because it looked goodAs you say, if Delrin handles, 1961 onward.
Boulder Colo as part of the stamps was dropped after 1972, so 1961 to 1972. Could possibly be no later than 1967 based on.....
Pile side model numbers started in 1955 and continued to 1967 on fixed blades, then shifting to the guards for late 1967 to 1976. Don't know if the model # stayed on the pile side for folders of if it shifted to the mark side at the time the stamp shifted to the guard on fixed blades. as fixed blades are my primary focus of Western studies.
If anyone has a Western folder (Barlow or otherwise) with a mark side model number and BOULDER COLO in the stamp, that would be an indicator that stamps for folders changed in 1967 when the fixed blade change from pile side to guard model numbers in 1967.
The 1978 catalog states that the 822 had brass scales. The 1968 catalog does not specify brass (or any other material) scales. Unknown as to whether the shift from steel to brass occurred in 1973 when many other line changes happened at Western or in 1977, when more changes occurred, i.e., year codes added.
A Western Barlow with a Western over USA 822 stamp with an "A" date code and steel scales would indicate that the steel to brass change occurred with the 1978 catalog. Brass bolsters on an "A" Barlow would mean we would have to find a Barlow with a WESTERN over USA 822 stamp and NO date code (a 1973 to 1976 knife) - to determine if the change occurred with the 1973 changes.
Thank you! Clear as mud, eh? So early 1960's through possibly mid 1970's.As you say, if Delrin handles, 1961 onward.
Wish I could get a picture of the mark. Don't forget the full third line. WESTERN over BOULDER COLO over MADE IN USA mark side stamp and a pile side 822.Okay - Just did a fleabay search on WESTERN KNIFE BARLOW. Results show TWO with WESTERN over USA mark side and 822 over BARLOW on the pile side. With brass scales.
This tells us that, at least for the Barlow, brass scales were introduced not later than 1973. Since Codger's pre-1967/1973 has steel scales, the introduction of brass scales is now either 1967 or 1973. IF, and it is a big IF, we can find a WESTERN over BOULDER COLO mark side stamp and a pile side 822 or 822 over BARLOW stamp.
I probably should have studied the folders over the years, but they never have been much in my collecting wheelhouse.
Proving a negative is hard, An investigation of Western Barlows MIGHT make it possible to differentiate between a 1967- 1972 Barlow and a pre-1967 barlow, but ONLY if the 1967-1972 Barlow stamped BOULDER COLO on the mark side and has Barlow under the 822 on the pile side (BARLOW is missing under the 822 pre-1967). If the 1967 - 1972 stamp is the same as pre-1967 Barlow, then only brass scales with a pre-1967 stamp would indicate that the knife was a 1967-1972. And solve the brass scale introduction quandry.
No problem!! Those three old NYKs are very relic-like, but walk and talk is as good as it ever was!!thanks for sharing those pics and the history!
