So, I wanted to do some side-by-side testing of field sharpeners anyway, and needed some extra field sharpeners for backpack, emergency kit, work, shed, and car. Got the DMT variant of the 2 sharpener options I listed above (the folding XC/C, and F/EF). This is also handy because I have a small number of knives with "super steels" (all folders or small fixed blades), and the diamonds can handle these steels better than the AF. I think this 2-sharpener little combo would make a welcome addition to a field sharpening kit, especially the backpacking setup where I'm likely to have 1 or 2 "super steel" blades along with me. I'll post back later when I get to try out the DMT XC in more detail as the primary grit field sharpener, that's the new part of the mix here that I've never had available to me before (I already have a C/F folding sharpener used for years, but the C has never been quite "C" enough especially for cleaning up dings and moderate blade damage in choppers and axes). I think the most interesting comparison is yet to be done, and that's between the DMT XC/C and the AF's 2 available grits. In that comparison, I expect the AF to be more versatile but we'll see.
Just a spec comparison of the AF field stone and these 2 DMT sharpeners as a set:
- Weight
- AF stone only (no carry case): 7.2oz
- DMT X/C and F/EF folding sharpeners combined: 5 oz
- Dimensions
- AF: 5.875" x 1.625" x 0.625"
- Sharpening surface area: 5.875" x 1.625" = 9.55 sq. in.
- DMT X/C and F/EF sharpeners
- Folded closed, and rubber-banded together the way I'd carry them: 5" x 1.12" x 0.871"
- Sharpening surface area (single sharpener): 4.375" x 0.894" = 3.91 sq. in.
Considerations based on what I know today:
- The AF is subjectively nicer to use. It gives better tactile feedback for feeling your edge than the DMT small interrupted folding sharpeners. This is user opinion but it's a very substantial difference to me.
- The AF gives more than double the sharpening surface area. This makes it easier to get a full sharpening stroke and maintain a consistent angle, and gives you more surface area contact with each stroke.
- The DMT 2-sharpener combo is more compact and portable than the AF stone. Compared to the AF, the 2 DMT stones rubber banded together are shorter, narrower, slightly taller, and 2.2 oz lighter. If portability is a concern--as for me with backpacking--this is worth considering.
- The DMT 2-sharpener combo gives 4 grits. The AF gives 2. The 2 grits on the AF are more than adequate for most field usage, as are the 2 grits on the DMT XC/C. But given how compact the DMT sharpeners are, it's a nice extra to be able to bring both in a super-light package and be able to refine a coarse edge with the EF stone to finish.
- The DMT combo will handle my folders/fixed blades in S30/S35/M390 a bit better than the AF. The AF can still sharpen at least some of these steels for sure, I've tested on S30v. But the AF is an AlOx stone, and the DMT diamonds will naturally handle super hard steels better.
- Overall: both of these field sharpening options are really excellent and IMHO, offer far more field sharpening versatility than any other freehand field sharpeners I've tried or seen reviews/specs for. Given a choice of the 2 and for actual significant sharpening work, I'd choose the AF. It's easier to hold and use, sharpens faster due to the greater surface area, gives better feedback for feeling your edge, and is just more of a pleasure to use. However, when portability is a key consideration, when finer grit options would be useful, and when I'm carrying modern super hard steels, the DMT would get the nod. Expect to find good use in my sharpening kit for both of these.
2 stacked DMT folding sharpeners next to AF stone for L x W comparison:
Stacked DMT sharpeners are about 0.25" taller than the AF:
AF weight:
DMT 2 sharpeners combined weight:
