DeadboxHero
- Mar 22, 2014
See post above.Most folks aren't.
I think the Pros are a good value starting point, but they also got me looking around.Depending on the stone 220 is usually where I start with a new knife to get rid of the factory grind.
So I am curious and looking forward to how the 220 Glass does.
I don't see a single advantage to water stones vs. modern diamond abrasives.Long post, so if you don't feel like wading through it, why do you recommend water stones?
I see no reason why Japanese water stones and freehand sharpening would be obligatory, just because the knife is Japanese. Don't fall for it!As some of you will know, my Japanese knife desires have again been ignited. ... the seemingly obligatory water stone sharpening, I've always found myself a bit overwhelmed and somewhat intimidated.
Again, I don't buy this. Why, particularly, must sharpening be done freehand? If you want it to be a sub-hobby or to develop that skill, I understand. But otherwise, you're just making it hard on yourself. I went through this phase as a young 'un, developed enough skill to satisfy myself that I could do it if I needed to, but quickly found that it's faster and wastes less steel and time to have some kind of guide. (exception being ceramic rod-type sharpeners, where I only have to hold the knife vertical)The first thing I needed to do was up my free hand game. ...
See how simple that is if you don't tie yourself down to Jap water stones? ;-)So, I found myself in this circle of, I want more Japanese knivesbut I need water stones and I'm not sure I want water stones or am not sure I can adjust so I'm not getting more Japanese knives... and round and round...
Don't bother with India stones either. Get yourself a KOWS and a Sharpmaker = job done. Heck, for kitchen knives, you don't even need the KOWS; Sharpmaker alone will do you fine.But this time as I was thinking I had a bit of an epiphany... Japanese knives aren't somehow impervious to my current sharpening stones. I know that sounds stupid simple, but I just, I don't know, somehow thought, that maybe an India stone was just too, um crude maybe? I know... But, that's what has been in my brain. Like somehow there was this intrinsic bond between the knife and stone and to not use water stones would be somehow bad for the knife... I know, I know...
My concise thoughts, itemized for your convenience. ;-)
(snipped the rest)
You can bet that if they had our sharpening means, the ancient Japanese would NOT have messed around with their water stones. If they REALLY wanted to be arty and do it freehand, they'd use DMT diamond stones. Otherwise, KOWS.
A perhaps controversial take: I believe most of the popularity of Japanese water stones over the last decade stems from fetishization of them by big personalities in the culinary and woodworking worlds rather than the specific advantages and disadvantages that they have. Rather than delving into the technical reasons for selecting them, those personalities have tended to laud them in very broad terms that aren't unique to those stones, but the masses have largely bought into that marketing angle.
To be clear, they're great stones, stylistically, but just one of many options available to you that are capable of producing high quality polished edges on modern high-hardness steels. The abrasive grain they use is no different from the range of various formulations of aluminum oxide and silicon carbide used in oil stones, and instead what differs is the bond type and strength and the grit size, which affects the grit/bond ratio, and inevitably also the hardness of the stone. Over ~400 ANSI grit (~700 JIS) you start butting up against an interesting issue: the grit becomes so fine that it is essentially more like flour or corn starch in consistency, and less like sand. The finer the grit the more binder must be used, which is less structurally durable than the abrasive grain, and so you inherently end up with a softer stone than the same grit type and bond with a larger grit size. This is part of why water stones tend to lose their advantages as you get into the coarse end of the spectrum.
Soft stones cut quickly for a given grit rating, and muddy stones will give three-body abrasion to polish up bevel surfaces and help prevent burrs from developing, but are liable to gouge under much more than light pressure, wear and dish out faster (be vigilant about using the full stone face to stave off the need for flattening!), and are difficult to create a crisp apex on using edge-leading strokes because of the free grit plowing into your edge (this is also what helps prevent burr formation.)
So much of stone selection simply comes down to what qualities you want out of it. As mentioned, broad bevels or flats tend to need soft stones because of how much they diffuse pressure, and so soft stones are great for that. But in terms of performance qualities it's important to know the context of use you're shopping for, and then translate that into the features and benefits you need in order to optimize the match of stones to tasks. For some knives and tools fine, soft stones are just the ticket--at least for some parts of the process. Muddy stones in particular usually are of greatest benefit as intermediary stones, for cosmetic surface finishing, and for sharpening broad bevels or flats.
This is all less organized or in depth than I'd like, but I felt it necessary to comment on the core of the question in the OP, as I hadn't really seen it dug into thoroughly.
I guess this thread is a good place to discuss the pro and con, is a long discussion.
Observation re the midrange muddy stones is spot on.
The Suzuki Ya stones are all VERY hard and generate only a small amount of mud, except for the 2k, which is nearly as soft as the Norton 1k. The final set-up stone before the 4k and up.
End of day, every sharpening stone has to deal with abrasive refresh (unless diamond/CBN) and removing the spent metal off the surface. Waterstones do a good job of this.
(snipped the rest)
For freehand I vastly prefer waterstones. When using my guided setup the diamond plates are more convenient.
I still will use diamond plates freehand as well, but only if convenience is important.
They are almost as hard as the Jumma Cobalt stones, which are about as hard feeling as a diamond plate.Chances are they have a very hard binder formulation worked out! Looking them up it appears they use a vitrified bond, but they must have worked out a suitably hard mix.
Arguably, even diamond stones can wear out on ya' eventually depending on how you use them and whether they're made of monocrystalline or polycrystalline diamond, or a mix of both. You *usually* don't run into that issue with using them on steel, but when using them to condition bonded abrasives they can eventually blunt like any other abrasive eventually does.
I'm not putting down freehand sharpening. It certainly is less equipment-intensive than any kind of fixtured sharpening.
The reason I said it is less efficient is that as a human, there is human error with regards to maintaining the angle, so in order to get it sharp, it takes more grinding. ...unless you're saying that you're more efficient than a machine, on which the angle is mechanically maintained?
