- Feb 10, 2014
A hex bit.Hey OP..my friend owns a Delica and his is stuff as a board..what did you use to loosen up the pivot ?
It s production knife and nobody gives it individual attention. So i took it apart, cleaned it and slightly polished the washer and the liner. Even the blade you can do it to in the area where it contacts the washer. All with 2000 grit sandpaper i had from store automotive section. Then, you can adjust the tension with pivot screw. It can be more free droping than that if need be. It's not that fun to take apart cuz it can get hard to put it back together. Id watch a disassembly video before attempting. Wash it first and adjust tension. Maybe that's all that's neededHey OP..my friend owns a Delica and his is stuff as a board..what did you use to loosen up the pivot ?
Due to some safety concerns exhibited in comments and me being a responsible bladeforums.com member. Please view this video to make sure you understand how to perform this technique safely. Thank you.
This is mostly for my own generation lol cuz i guess you can't teach old dog new tricks . No offence i respect older folks.
Thank you for your concern . My knives are in very dependable condition. Upon examination you wont be able to locate any damage. There is no bladeplay. In the closing method demonstrated I am pretty much escorting the blade to it's closed destination. I can do it just as fast and you won't hear a sound. When I flick it out, the blade it's very light and the surfaces are very large and tight, contacting together flush, that it has no detrimental effect whatsoever. This isn't your sebenza friend so don't be afraid for it. You probably been closing your slipjoints for ages, smacking it closed and nothing ever happened to it. This knife is intended to be pulled out in a pinch to cut something to get free. I'm getting better with these videos i can make one just for you explaining anything else you might have missed. Like i said no offence.It's not about teaching an old dog a new trick, it's about the old dogs having been there, done that and knowing that keeping a knife in good working, dependable condition takes using the knife the way it is designed to be used.
Awesome ! Thanks for the tip manIt s production knife and nobody gives it individual attention. So i took it apart, cleaned it and slightly polished the washer and the liner. Even the blade you can do it to in the area where it contacts the washer. All with 2000 grit sandpaper i had from store automotive section. Then, you can adjust the tension with pivot screw. It can be more free droping than that if need be. It's not that fun to take apart cuz it can get hard to put it back together. Id watch a disassembly video before attempting. Wash it first and adjust tension. Maybe that's all that's needed
You didn't show the bleeding yet. Fool around with lockback knives enough, especially trying to close them one-handed, and they will get you.
I guess i missed something. What's so special about the Spyderco version of the back lock? Several companies have been using it for years and I have been closing them one handed for years, not with that speed, but what's the hurry anyway? My favorites are my Case Copperlocks.
I'm going to attempt this right now. If you hear back from me that means I survivedSome Spyderco models also allow an alternative method to close a backlock knife: with your thumb in the Spydie hole, place your ring or index finger so that the bottom joint of the finger can press the lock, and the tip of the finger is wrapped around the front of the handle to exert some extra pressure. With some models, you can squeeze hard enough to disengage the lock, and because your thumb is in the hole, you can close it deliberately and safely once all fingers are out of the way. This is usually easier with the older generation Clipits, but I can do it with my Delica 4 as well, just a tad trickier.
Cool, I hope my description isn't confusing. I think I uploaded a video where I sort of demonstrate the method with either a Harpy or Gen 1 Endura....
Something to consider w/ this technique
is that the earlier Endura shown lacks the Boye Dent on the back lock, making it easier
to depress the lock w/ a handle squeeze.
Okay, yes, here it is used on the Endura:
im not a fan of backlocks, .
