your crucible link doesn't work
TOO many variables to just talk about steels in general or to answer your original question, it just won't happen because the answer would change as the variables do.
No one steel is perfect at everything across the board....
The are no free lunches with steels at all, to get something we have to give up something else or a number of things.
The only real answer is that there isn't an answer.
There is a graph on Crucibles website, but that is just for reference.
http://www.crucible.com/PDFs/Knifemaker REV June 2010.pdf
can you list the 10 steels that you were putting before M4?
for information sake, i like to know what's what, it would only help
I know of cts-xhp, Elmax, K390...what others?
That's a nice link, Jim. I'd not seen that one before. Saved that one on my hard drive. THANKS!
I agree with you. There is no one steel that is optimal for all uses, even if you vary the heat treat. There isn't even a single steel that is the best for a single use.
As you say, the problem is too complex to be boiled down into a simple graph. The most I've ever tried to do is to chart a rough comparison of edge retentions of alloys that are pretty much the same hardness using a measuring method that minimizes the effects of blade shape.
What Spyderco calls CTS-20CP, using the "CTS" which indicates a Carpenter alloy, Carpenter apparently calls "Micro-Melt 420-CW Tool Steel. The compositions are a dead match. I fear you will need to log in to the Carpenter web site to view it, but the datasheet is here, though the format is so different from that of Crucible that I fear you'll not have much luck with a comparison:
http://www.cartech.com/techcenter.aspx?id=1692&searchtext=cts-20CP
Checking out this URL and digging down to their wear resistance test gets you to this page.
Scroll down to Wear Resistance and look at the table.
The number progression is pretty impressive.
http://cartech.ides.com/datasheet.aspx?E=339&FMT=PRINT
You may have to click on the quoted URL first to access the second one.
He already did in this thread.
You can't talk about "steel." You have to take into consideration hardness, primary grind, secondary bevel, etc. Differences that seem small can make a big difference.
Everything matters for sure, then there is perception or perceived performance of one steel over another, and don't forget Urban Legends.....
M4 really isn't all that great, well maybe to some who haven't seen or used that many steels it might be, but there are a lot of better choices out there.
Most balanced steel?????
Compared to what?
Doing what?
M4 is OK, but not even in my top 10 of steel choices.
Until M390 was introduced into the knife industry, I think M4 provided high edge retention along with the ability to take and hold a razor sharp edge. Sure, S90V would hold an edge longer, but S90V is quite the rare animal aside from an occasional sprint run and a couple of customs. M4 is actually used in production knives, though I only trust Spyderco with the heat treat.I have come to this conclusion also recently. I have put M4 to the test and it does perform fairly well, but not nearly as good as some of the other steels in it's range - and it's not even stainless. It gives nothing that you can't get in another steel that is actually stain resistant.
