I agree totally, if anyone considered it a "problem" in the first place.The detent to keep the knife closed is actually a little tighter now and more secure. The knife still easily flips open. The actual adjustment & disassembly took less time than writing this & taking pictures.
This knife is just too nice to let everyone lose hope in it after just a couple days.
That is a nice fix as long as the pin does not rotate. :thumbup:
As you slowly open the blade now, I would assume you can feel the ball detent drop into the hole and come out???
And on closing the blade it goes into the hole and comes out as the blade goes to the final resting spot against the modified stop pin?
BUT, I would like to know where the detent ball is now resting when the blade is in the fully closed position. [to satisfy my own curiosity]
I would assume it is no longer in the hole, is that correct?
Thanks in advance....
Thanks for the info.... I haven't even had mine apart yet as it really doesn't bother me as is.The pin is pressed in pretty tight on mine and does not roll around without using pliers & some pressure. Plus the flat of the blade rests on the now flat ground (on one side only) stop pin.
Yes blade now snaps shut with a nice little click when it hits the stop.
My blade now requires a bit of thumb pressure to get it opening. Not bad, but a reassuring "it is not gonna open in my pocket" amount of pressure.
Every knife I have ever owned needed some kind of tinkering, I don't care who made it. Whether is was sharpness issues, blade play, or just plain bad finishing. This needed an easy fix and is rock solid otherwise from what I have seen.
Thank you, that is what I wanted to know. :thumbup:I did not pay very close attention to what the lock & detent did prior to my tinkering. Now however when the blade closes fully the lock side & detent ball seem to drop in the hole of the blade and hold it closed. I did not check to see if this happened prior to grinding the pin.
It for sure locks closed better than before, and the blade is fully behind the scales.
Yeah, my ball detent rests squarely in the hole when the blade is at full close.No problem. So yours drop into the blade and locks it closed now as-is. Mine locked close before, but is better now. I just never noticed the lock snaping shut.
I was not worried about the blade before, but just wanted to see how easy a fix would be.
How about making a secondary detent hole on the blade after playing with stop pin???? I don't mind secondary hole to keep it shut. The reasons for having ball dentent hole is to keep the blade from accidental opening without pressure or force. I would not trust any frame lock or liner lock if the ball does not sit well in the detent hole.
Ford Freak.
The world is about adapting, surviving and enjoying the accomplishments. Have at it and let me cover your costs and send you some swag. You know where to reach me.
And yes regardless of the mods you do. We are going to make your knife hum like a V12 at no cost to you. Life is too short to think of more reasons to complicate your life.
When you are a member of the DPx Gear family you get treated like family...unless you are the village idiot of course )
Sounds fair. As long as the pin option isn't the only thing being considered, I can wait it out....So I don't know that a longer blade is the fix or even a pin change [bold added for emphasis] but I do know that there is some work to be done.
