bigmark408
- Nov 13, 2006
Hi guys, I think I might be helpful. If my english will handle it
1.Test purpose
Test might seem a bit abusive for many, but the purpose of it was not only to test the knife but mainly to test new solutions used in this design. Of course that most of these knives won't see such kind of use but there is also possibility that such a test can show performance of a knife after years of constant but typical use - and that would show us benefits from innovative solutions.
2. Potential reasons of a lock failure
I will relate to this post by STR:
http://www.bladeforums.com/forums/showpost.php?p=7691387&postcount=91
Because I personally think that it's the most coherent one and sums it all up pretty well.
Potential reasons for a fail of lock:
-shock of impact connected with mud, water, oil form washers etc. in the lock - well, knife was cleaned, so there was no mud, maybe water and oil - but this and only this can't be a sole thing responsible - Sebenza after such treatment do well, also Tenacious as you can see on a video and so on
-what above + overextension of the lock (being investigated, maybe there would be also some video, personally I don't know), I think that maybe a stopping disk for a frame lock could be helpful and easily prevent overextending
And I'll add two another reasons:
-fail of this one particular knife (being investigated)
-fail of the design - maybe too much wear due to ceramic ball, but it's too early to draw conclusions
3. Further to check
So now when oil & dirt is checked it's about:
-whether only overextension can be a reason
-overextension with oil, water and so on added
That can be checked on other frame locks or as well - another Umnumzaan.
Then it's about one knife accident or a design.
If overextended dirty Umnumzaan will perform good, then it's a time for another round of harsh tests - lock fails similarily - means yours will do that also but, let say, after ten years of use, while Sebbie would have lasted 20+, otherwise it was only an accident and shouldn't be taken into consideration.
I don't know if such tests will be performed and so on, maybe someone from here can also try that - overextend - check - make it wet/use some oil - check. Additional data could be helpful.
4. Present status
BUT - at now procedures are not ended, what you're getting here are some glimpses of what is being done or what has been done in the past and with no proper background these information are useless for you - so please - ignore them. Without reading a thread on knives.pl which is waaay bigger than that one - there is no point. There was NO intention of releasing this info outside on this stage.
There will be given an official (from the forum as a whole) summary and explanation in this thread but in the end when everything will be clear. Till this very moment - everything you may see may be taken out of context and simply useless for you - so please do not judge it lightly as we do not judge lightly Umnumzaan.
It would be courteous to properly introduce yourself.
I consider it dissrespectful not only to CRK but to all the members here that you make a first post with out a proper introduction. .
It's completely obvious that the lock in your video failed because of over extension of the lock bar....that blade is not rolling through the lock in battery.
