traumkommode
- Dec 3, 2015
Glad to have a review of the pulls.
Looks like you should have no problem acquiring. This run of 82s seem to be readily available.Want this copperhead covered version like the shield on it too. Glad it’s a Tidioute plain bolsters and satin blades no etch nice and simple.
I believe those variants were the only ones released at this point, correct?Apart from micarta and copperhead I dont see any others about the dealers....ive got a copperhead en route.
My micarta Dixie stockman arrived yesterday, and I’m pretty impressed. The small clip and wharncliffe measure between .020” and .025” behind the edge. The main clip is a wonderful .016” to .020” behind the edge. It cuts like a scalpel.
GEC did a great job of polishing the micarta. No spring gaps. Springs are flush with the blades both open and closed. I love the lack of half stops on his model. Somehow GEC put this knife together with absolutely zero blade rub between the three blades. No lateral play on any of the blades. All blades arrived sharp. Very impressive fit and finish, which is the hallmark of GEC.
This is a pretty sizable stockman, and very comfortable in the hand, but the 2-spring design really keeps the weight and bulk down. Turkish clips aren’t exactly my thing, but the low profile shape does work well with the streamlined approach to the Dixie. It’s a good choice on this model.
My only nitpick is with the pulls on the blades. I’m not a lover of nail-breaker pulls, but these pulls are a bit light for even me. My Case medium stockman actually has stiffer pulls than my Dixie, and Case isn’t exactly known for their strong pulls. The snap is good on the Dixie blades though, so it’s not really too bad. There’s easily enough force to close the blades without a problem. I’d prefer pulls of 4 and 5, but I can live with 3 and 4 initially. The snap will probably only get even better with time and use, so it’s okay I guess. Not great but good enough.
All in all, I’m very impressed. Nice size for hard use. Great blade selection. No broken nails. Indestructible covers. Superior cutting efficiency.
I’d really love to see a stainless punch stockman next time around!!!!
Man this look nice!
I haven't kept up with GEC for several years... do they do this blade set--love the long wharncliffe and drop/clip instead of a spey-- on a smaller frame?
G
Makes sense to me.So I might be an oddball here, but I think light pulls are appropriate on Stockman, Whittler and Congress patterns.
With blades all nesting so close to each other, a stiffer pull would likely result in nasty blade rubs.
I'm going to give one a try. It's a big knife but I like the 81 too.
