Spydusse, no arguments from me. It's a nice steel. Not much different from CPM D2, which I also liked but in what way does it perform better than Elmax for you?
I get a better edge, easier sharpening ( with diamonds) and better wear with Elmax. Elmax to me is like a S30V that likes to get sharp, and stay sharp. It has those vanadium carbides that cut all day, but it seems to keep high sharpness better than S30V IMO. That was always S30V's weakness. The reasons have been argued for years here and elsewhere.
CTS-XHP ( a powder version of the old 440XH ie: stainless D2) just has chrome and iron carbides and when the going gets tough, I'd think the XHP wouldn't last like a vanadium steel in certain mediums. In things like skinning blades the D2 blades have always excelled.
Still, I don't have years of experience with either steel like I do S30V, Ingot D2, S90V, etc.
Thanks. Joe
I told myself I was only allowed to get one para 2 and because of xhp preformance I picked the cts20cp and am still waiting on it.
I sure hope so because from now till August I put in 60 to 70 hr weeks . So I lack the time to sharpen or will to anyway. Usally I cycle threw blades in this period of work year . That way I don't need to sharpen.
I just purchased a Spyderco Manix 2 in CTS-XHP from a forum member. I will test this out in real world environment situations and give my report asap.
Alpha
Instead of treating them like superior beings, how about treating them as people with more experience than you?
How many knives have you made or designed sir? None? Great, so stop talking.
Anyone knows when that's coming out? Because at this rate I'm afraid they'll be shipping the knife to my next of kin.I told myself I was only allowed to get one para 2 and because of xhp preformance I picked the cts20cp and am still waiting on it.
What the hell are you talking about? What D2 did I misrepresent "referring to obviously failure in HT" ? You make no sense whatsoever.
Judging from the knives in the link and the exact identical appearance of the various blades(aside from the handles), I don't believe putting a blank blade in a handle qualifies as "making your own knife". It doesn't look like you were in any way involved in the process of heat treating, tempering, grinding, or finishing the blade.
Thanks. Joe
That's exactly what he did, described in plain Russian on his site. A lot of folks do the same, but as usual they call it re-handling, or handle making, but nobody except him claimed knifemaking based on that.Judging from the knives in the link and the exact identical appearance of the various blades(aside from the handles), I don't believe putting a blank blade in a handle qualifies as "making your own knife".
Did not we discussed that earlier? You talk a lot about CPM S30V being better that D2 cutting Carpet. Turns out that you were using Benchmade. If you check my tests - D2 from this manufacurer I have show worse results among all tested. So you were talking about wors possible D2 not the one heat treated by Dozier, I refers.
As you may see it is important to know what steel are you talking about. May be your sample of CPM S60V is not representative, as it was in case when you talk about superiority of CPM S30V carbides over D2 steel.
It sounds very pretty, however tests as well as practical use does not support that. CPM S30V pretyy average performer and Elmax is exactly same.
If you try to compare it not to BM D2 but one which is heat treated as it suppose to, you may notice that CPM S30V way behind.
Thanks, Vassili.
For some reason you think any of your samples of one or two are any better? How many XHP knives have you tested to make it more representative? Anecdotal reporting is fine, but it is also equivalent to other anecdotal reporting - not superior.As you may see it is important to know what steel are you talking about. May be your sample of CPM S60V is not representative
Best I recall you have never seen this knife nor do you have any idea about how it is heat treated. Your ideas of performance only prove anything to you. No one else. To think you can judge a knife you've never seen by your tests is one of the stupidest things I've ever heard. To call mine a "failed heat treat" without ever even seeing it is extreme stupidity.
Knives moron. KNIVES. You test knives which gives you no insight into steels, much less other peoples knives. You have no idea what you are talking about again. You have had this explained to you so many times yet it never has sunk in.
You know without examining my knives how it performs? You know the hardness, the bevel angles, any possible modifications from stock, finish type etc? Wow! You need to work for the CIA, or FSP or someone who can use your remote viewing abilities.
But first learn something about knives if you are going to post here. You're stinking up the place.
Joe
