- Jul 1, 2016
Does anyone know if any will be made with green micarta? More specifically the Bushmasters. I will hold off getting one in black if some green ones are going to hit the market at some point.
The Bushmaster I have been checking out has green scales, so I would think that would be one of the options.
Don't let that stop you from getting a black one...remember 1= none and 2 = one...Or something like thatCool. Thanks!!!
Well I have been looking for something like this for awhile. Right blade length, right thickness, and in AEB-L. Plus it's made by Andy and crew, so I may end up with two anyway...Don't let that stop you from getting a black one...remember 1= none and 2 = one...Or something like that
We will definitely be using od micarta on these as well.
!!We will definitely be using od micarta on these as well.
They would enjoy a Trailmaster. It's a really good size for a do-just-about-everything knife - 4" handle, 3 5/8" blade. The cutting edge on mine is right about 3 1/2". I will say this knife was not quite as sharp as my Fiddlebacks and certainly not my OKTs. That's not to say it wasn't sharp, it just didn't glide through copy paper as smoothly as those others.trail master for some future classes
I sanded the edges of mine last night, and here's a before & after photo. The difference is visually subtle, but tactilely it's significant.
Looking forward to that answer as well. If may add. I’m going to try 220 and see if that makes any progress. If not 120 and then progress to 220. Once I like it i’ll move onto 400/800 (maybe 1500) but end up polishing with some pink no scratch. See how that does.
I don't think I can capture that very well in a photo, but below is my best attempt. The very bottom of the scales are ground flat with the tang. The side is curved, and where those two meet (identified by the arrows in this photo) had a slight edge. It was not as pronounced as the edge at the butt, and I wouldn't say it was really uncomfortable in the hand, but it was distracting. I suspect it would become more noticeable if using the knife for a long period of time. Yes, ministrations were effective. This photo is after the sanding; I didn't take a before picture.Could you please explain more about what you mean by "along the underside"?
Did your recent ministrations take care of this area, as well?
I may have cheated a little. I have an entry level 1 x 42 inch belt sander from Kalamazoo Industries, and used it to knock the edge off these scales. I didn't want to take much off, so I used a 1000 grit belt just on the butt's edges. I finished by briefly hand sanding with 1500 and then 2000 grit paper. I tend to use finer grain abrasives. I only hand sanded the underside, and the progression I used was 800 -> 1000 -> 1500 -> 2000. If I were to this again, I'd start with a coarser grit, probably 400. Again, I only wanted to remove a tiny bit of Micarta.To add further: what grit sand paper did you use
You're very welcome. Something about the Trailmaster I neglected to mention before is that it's a fast handling knife. It feels very nimble. Maybe not as much as an Elf, which is incredibly light and fast, but it feels very maneuverable. My Trailmaster weighs in at 3.8 oz. The balance point is between the first two pins. I have found a four-inch handle to be just about perfect for me in a general purpose knife. It provides just enough room without a lot of extra handle to get in the way. I'm really liking the Trailmaster and expect it will accompany me frequently in the coming months as I'm doing things outdoors.Thanks for posting your thoughts folks.
