- Apr 29, 2022
Sorry, I don’t know about the wood scales. I’d leave them til later anyway. So you’re sticking to 91mm?Do you know if the wood scales are snap-on like the plastic, or are they glued on?
Well, since I have the 91mm Hiker alredy, and I really like the setup with the philips and saw, I think it´s the easiest way to go. And, the Alox 92mm awl have the right thicknes for that frame so it should fit without any filing or extra washers. I do think the 84mm is a better pocket size to carry all the time, so maybe I will try to make one some day if I can find good donor parts.Sorry, I don’t know about the wood scales. I’d leave them til later anyway. So you’re sticking to 91mm?
Thank you for the input. Did you pre heat it or something before trying to pry them off?They're both, kind of.. I swapped 85mm Evo wood scales with plastic.
Snap on but not even close to Cellidors, & I believe they were glued on, I re-glued them on different Evo & they're perfect, a tighter fit than the factory's really.
1 wooden scale was slightly damaged, but no wood fell off, I was very careful.
I feel you. As tough and functional aluminum is - it is quite cold.. literally and figuratively. I don’t like the feel and the idea of the ”flakey” coat and material. Some kind of paranoia from aluminum pans and studies of alzhaimer associated to aluminum? It is the perfect material for keyring tool though but doesn’t wear very elegantly.When I made my first mod it was from an Alox, mostly due to the tools being a little bit heavier. I especially find the awl to be a go-to tool instead of a pen-blade. But I don’t like the feeling of the aluminium in hand, and I almost feel that the hollow plastic are too light… My favourite at this time is the Hiker in wood. I am thinking of making a mod of that model with a SD scissor on the backside instead of the sewing awl, and replace the pen blade with a awl from an Alox. Then I just need to find a shrinking machine and make it 84mm instead
Look at it as a premium improvment, not a modI feel you. As tough and functional aluminum is - it is quite cold.. literally and figuratively. I don’t like the feel and the idea of the ”flakey” coat and material. Some kind of paranoia from aluminum pans and studies of alzhaimer associated to aluminum? It is the perfect material for keyring tool though but doesn’t wear very elegantly.
In other hand the plastic handles feel.. plastic. It makes the otherwise great tool feel cheap. As much as I love the good ol red SAK they just don’t have that heirloom vibe to them.
Maybe I need that custom SAK after all.. me, custom hater.
With a premium price tagLook at it as a premium improvment, not a mod
Not the wooden scales.. They weren't as well fitted as Cellidors anyway, it was easy.Thank you for the input. Did you pre heat it or something before trying to pry them off?
