Kind of a new development so I am adding a new post to hopefully make it a little more noticeable. I never really intended the 300 Matrix stone to be a brute reprofiling stone, the resin just isn't tough enough to do this. It will remove metal nicely but you just can't push on it like most other stones. The Matrix stones niche is for high quality refined scratch patterns and minimal metal deformation at the apex, not brute metal removal. I have been talking with EP about this and Cody is going to add this info to the description, once we settle on the wording and he has time. In the mean time I want to get this info out there to help everyone in deciding if and what Matrix stones they may be interested in. The pass-around should be leaving loonybin any day now and going to Fixall next so they can start giving their opinions of these stones.
I got to try out a partial set of Venev diamond stones a few weekends ago and I really liked the F150, which is an 80 micron abrasive like the Matrix 300. The Venev removed metal quite a bit faster but left a much bigger burr, which tells me it is deforming the apex more. The Venev needed a lot more pressure to work than the Matrix could stand so it was a really interesting test for me. It has prodded me to work on prototyping some roughing stones using phenolic resin, which is what Venev and I believe Poltava use. I have had a kilo sample bag of appropriate phenolic resin for a few years now, I just needed a kick in the ass to try it out.
When I get a chance I will do a review of the Venev stones like I did of the SG stones.
While giving updates I might as well add that I have started finishing with 2 or 3 passes with a denim strop loaded with diamond and wax, just stuff I have lying around. It just seems to be the next step after the appropriate diamond stone, and makes a noticeable difference to the keeness of the edge. The diamond I use is the same as the last stone I use. The diamond leaves a much finer scratch in denim than the resin bond. I will be getting some leather to try to see how that compares to the denim. Too many passes with the diamond loaded denim will certainly round the apex dulling the edge. My opinon right now is no need to go below 5 micron on the diamond since it doesn't do much, at least from what I can see under the microscope.
