I like synthetic materials only for the durability and all weather uses. This will be my first attempt at this, so hopefully I don't screw it up to badly. Thanks
rodriguez7
Yup, I am. But I'll try and make a solid handle out of g10. I'm thinking this knife will hold up regardless, as long as I don't put it through what I put my busses through. I'll be avoiding heavy battoning with this knife from now on. But for such a big thick blade, I figured it would have a much heavier duty tang.
Some thoughts after rereading this thread.
The Volcano tang sure looks very narrow to the blade, but:
If the spacers, guard, pommel and the new G10 handle are tightly aligned and secured with the pommelnut, I think You will be able to continue to do heavy batoning and chopping.
That is of course if You follow Bluntcuts advice about using a large hole filled with epoxy + filler.
Sawdust will work, but personally I prefer cottonflock or microballons and that will also work.( I took a 40 hours evening classes in 1984, on W.E.S.T. epoxy techniques.)
I have a few Bark Rivers with narrow tangs on heavy blades (just like the Volcano) and they certainly cope with very hard batoning.
The tricks I use is not to put pressure on the handle and I keep the blade leveled at 90 degrees to the wood beeing splitted.
The handle should never be allowed to act as a fulcrum.
If the wood refuses to split, I change from the knife to wooden wedges not to risk the knife.
The positive thing with this failure, is that it was the woodhandle that broke and not the tang.
A broken handle is fairly easy to replace, but not a broken tang.
I also like Your attitude to fix the problem by Yourself.
That's what I think any genuine Outdoorsman would do! :thumbup:
Regards
Mikael
