rodriguez7
Gila wilderness knife works
- Feb 1, 2009
Messed up!!!!
Messed up!!!!
Well , slow and patiently is answer ....................
I do not know if to me is allowed this, but ...................This summer comes my friend from USA in Macedonia and I can give to him enough big piece of solid Micarta for two handle .He will send to you when he come back in USA .......... free of course ?
Messed up!!!!
One of todays most prized lumbers for its outstanding color and figure; yet also one of the most infamous for its difficulty in gluing
Mikael , as I know due to the high oil content cocobolo is very difficult to glue . Maybe that was part of failure on this handle ..... ? Idea to put more spacer is fine , maybe some nice piece of wood in front ?
From wood.database.com
Not from oilcontent, that made the wood crack, I mind because of oil maybe wood did not glued to tang...
Fast chop and baton can put very large sheering/torquing-force on the neck of handle of a stick tang blade. Cumaru wood is crazy strong+tough interlocked-grain, even with that - I managed to crack the cumaru test handle 5+ times in the past (while testing blade). Cocobolo is mostly straight except some with minor interlocked grain, so it's not a good choice of handle wood in OP's situation. If camphor burl isn't too pungent/smelly (for my nose), it would be great for high impact handle (sure it would dent). Lately I'm not using camphor much because it is very difficult to remove the temp handle - yeah heat(and freeze doesn't worked well) & chisel but still hard.
Maybe this knife, used this way, would be a good candidate for a horse-mat handle. See if you can crack that.
