Ok, this Bass Pro 110 cut nice. I believe the blade coating has a play in making the cuts smoother. I stopped cutting at 70
hand fulls. Not that the last 5 or 10 hand fulls were cut well. I knew there was no need to proceed and say it was still cutting at this number. Because cutting well it was not. Thinking and giving an accurate statement, I think it cut well the same number as s90v and that would be around 55 hand fulls. Starting out cutting well and as you progress one can tell when it is deteriorating. There were little differences with the Way the 2 knives cut. Slight but present. The cpm154 seemed to slide thru the cuts better, once the cut was initiated.
Upon, examining this blade with the 8X headset, I noted of course the edge is all rolled but mostly to the right side not both sides. Then this edge is not as worn down as the s90v blade. I recall reading that Buck targeted this steel to 60RC on heat treat. Where as the s90v was targeted to 58RC. Thinking on it, then the s90v uses it's content of vandium carbides toward edge
retention and the cpm154 uses it's hardness. As the later does not have the carbide content of the first steel. These 2 steels are very close in their edge holding abilities. Not going to inflate one over the other, I'd rather just give you the straight skinny. Especially, when they were this close.
I will say both these knives are very top shelf models. The handles gripped well and were comfortable. The lock held. My Bass Pro has finger grooves. My hand never slipped. An important item because this cutting was not light duty and I kept doing it. So, your grip can get fatigued and a slip would be bad.
The last item is sharpening the blade back to a good edge. I've not done this but still, this will give us information toward all the factors of these knives. So, when I get that done I'll let you know. Thanks, DM
