Thanks John, blade is 16" really my attempt at forging something that big. For some strange reason my right arm is a little bigger that my left. I didn't realize how hard you have to hit something to move that much metal!Looks great Scott, what's the blade length?
I know even less about hammers and there use.What kind of hammer are you using, not that I know my arse from a hole in the ground, but when I went from a flat face cross peen to a rounding hammer, things moved twice as fast. Not sure if that would make the bevels harder to clean up or not though.
That should work, but you would want some kind of shoulder on it to keep it from wedging down into the hardy hole.I'm gonna try to make a Bick out of this, the horn is too big for the small stuff I've been doing. I figure I can fit the big end to the Hardy hole, draw the point out thinner , and put a 90° bend in it . That should help with smaller curves and pigtails/rat tails.
John, do you have a leg / blacksmith vise?Talk about TV or Sports and I'm tuned out by the first sentence (except old westerns) bring up blacksmithing or knifemaking and I geek out.
A friend of mine pulled the trigger on a gas forge from Majestic Forge today. Bringing him a rough old vulcan anvil that I've had sitting on top of a fencepost for the last few years. It's rough and has a broken tail, but it's a start. Threw in a couple of old hammers, I'm a bad influence.
Speaking of geek talk, my Bick is gonna be a small cone mandrel instead, thinking that will be easier to work curves on if I can look at them from the top. I guess the drawback would be not being able to hit it as hard but I'm usingostly small stock.
