- Jan 4, 2016
Hapstone V7 knife sharpener utilize square-shaped components to deliver ultimate precision.
HAPSTONE has just launched Hapstone V7, 7th generation of successful V-series. Hapstone V7 is being heralded as the ultimate knife sharpener with ability to use thousands of sharpening stones. The new Hapstone V7 delivers breath-taking features while pushing the boundaries for knife sharpening enthusiasts who demand the best.
* New High-precision universal stone holder and pivot rod of Square design with built-in digital gauge holder
* New Pivot unit and pivot rod holder of Square design with “zero wobble” inserts.
* New Anodized coating for extra durability
* New Suitable for sharpening stones up to 210 mm
* New Any sharpening angle in a range from 11 to 47 degrees
* New All basic parts including thumbs are made of metal
* New Thickness compensator of Square design allowing for sharpening stones of different thicknesses
* New Three Point Guide of new design for a high-precision knife positioning
* New Light-alloy horizontal shaft for better pressure control during the sharpening process
* Full compatibility with Edge Pro and KME stones
* Rubber covered blade table to protect your knives from scratches
* Detachable strong neodymium magnet to facilitate knife fastening
* Rubber coated supporting legs that can be used on any surface
* No-tool assembly for fast deployment and mobility
* Parking hook for horizontal shaft
* Metal pivot unit with PTFE insert provides smooth shaft movement and requires no lubrication or cleaning
* Spring for quick changes to the sharpening stone
* Stopper rings to limit the movement of the horizontal shaft
* Wooden handle to make time-consuming work a little easier
These specifications enable Hapstone to deliver an industry leading high-precision knife sharpener to the market.
Note. Due to major changes of form-factor Hapstone V7 is incompatible with V6 accessories.
Hapstone V7 will be available in 4 bundles:
* Basic – 3 grits
* Diamond – 6 grits
* Silicon Carbide – 5 grits
* Aluminum Oxide – 5 grits
Hapstone provides 5-year worldwide warranty on Hapstone V7 knife sharpeners.
* Basic – 3 grits
* Diamond – 6 grits
