This is an early unit, I think the new Hardcore uses a rubber wheel for the tension idler? I am not worried about it. Should have got a horizontal many years ago!
What kind of mechanism will you be using for tracking?
I was thinking about how on my current horizontal (just my first vertical build flipped, not a very well thought out machine but got me going) I tend to wear out linear tracks in the belt when using a work rest. My work rest is not very adjustable in height. I've seen people get around this by stacking their workpiece on 123 blocks, or other spacers, or having a vertically adjustable workrest - but those that I've seen would almost all require re-squaring to to the belt face. So I was thinking about how to get a rather significant amount of belt tracking movement, to move the belt rather than the work...
Then I thought about our platen collaboration. If you took the squeeze block, rods, and platen mounting face and turned it on end, you've have a quick, vertically adjustable workrest that stayed square to the belt when moving up and down. So I'm going to incorporate something like that, since it's relatively simple to make. The squeeze block could be mounted on a pivot to allow angular movement, but when set, vertical movement wouldn't change the angle.
I'm not sure the tilting tool rest is all that necessary - how many different places do you need the tilting tool rest? I use a few different places, but they work pretty good on the flat platen, or disk grinder. I was thinking the tool rest would need the up 'n down adjustment, but not much else. Might be good to move in 'n out to allow room to replace belt, then move tool rest up close to belt for some grinding steps.
I don't make all that many knives/mo, but I enjoy making tools almost as much as knives {g}. I just love to make a nice tool that works good, step back and say "I made that" {g}. I just finished making a Moen grinding jig that works like a champ.
I do plan to do lengthwise blade bevel grinding on this, dropping the belt off the 3 inch corner wheel straight to the top of a long radiused end platen (Nathan's).
I watched the video of Nathan doing the lengthwise blade bevel grinding - boy does that work nice to clean up bevels. I do that on my 2X72" grinder by removing the top platen wheel, and using a special long platen with a radiused end. If that could be worked into the horizontal it would be nice. I'd given it some thought, but didn't see a way to do it right off. Perhaps a long platen with a radiused end to fit right around the 1/4" small wheel grinder? so the belt would have the 1/4" wheel to roll around rather than a solid platen end?
Yes sir. Thinking of putting in the mount similar to the new Esteem platen so it might be switched out.Platen between the 2" and 3"?
I like it. I think it will work well and separating the tracking and tension will simplify things. I think a horizontal grinder is the ideal place for a tension mechanism that uses over center or a ratchet, only because I think threading a belt on will be a 2 handed operation, but other than that it does everything I would want in one.
