- Jun 3, 2017
Waiting on a kapara instead I believe
There is one on the exchange now.Waiting on a kapara instead I believe
Question for those of you that currently own the Ikuchi. I’ll preface by saying that I really like the knife. The profile is awesome, I find the design appealing, and it is one slicy mofo. Having said that I have some questions/concerns about the one I just received.
It was very tight upon receipt. It wouldn’t flip at all. Beautifully centered and excellent fit and finish but it wouldn’t open without big effort and some major wrist flicking. I put some KPL on the washers and worked the action a bit. Better but not as it should be, still wouldn’t flick more than 10-20% reliably.
I then loosened the pivot some and voila. I could flip it open nicely and it would smoothly shut without much trouble. Here’s the issue. No matter what I did other than keeping the pivot to the point it wouldn’t even flip, the side to side blade play was significant enough to be bothersome.
Question, for those who’s knife flips smoothly and reliably do you have any side to side blade play?
If I can’t correct this I will return it and try another one.
Opinions welcome.
Mine was "tight" out of the box. Not so tight that I could not flip it open but tighter than I prefer.
I oiled and adjusted the pivot w/o taking it apart. Hardest thing to do was to keep the blade centered while adjusting the pivot. It flips smoothly and easily now. I find the jimping on the flipper dial too abrasive and less effective than using a finger nail to engage it in order to flip the blade open.
However, the best way to open the knife IMO is to just to flip it open while releasing the compression tab (which unless you have really slender fingers, again can best be done w/your fingernail.
Any blade play on yours after you dialed in the adjustment?
No play in mine. It was a little tight at first, but is breaking in nicely.Question for those of you that currently own the Ikuchi. I’ll preface by saying that I really like the knife. The profile is awesome, I find the design appealing, and it is one slicy mofo. Having said that I have some questions/concerns about the one I just received.
Opinions welcome.
With this in mind, one of the first things I did when I opened the box was to rub the dial jimping; I didn't think it was abrasive at all. After flicking it a number of times I now have quite a few scratches on my index finger, so I notice it now. Still, it's probably the fastest action on a knife that I own, it's crazy how quick the blade jumps out.I find the jimping on the flipper dial too abrasive
I did manage to nick myself last night too. I brought the knife out of my pocket and kind of fumbled it in hand and received a small but deep-enough cut on the distal pad of my ring finger. It's a shame too, because if I put pressure on the closed knife it'll put the tip down about 1 mm or so, which is all that is needed to keep it safely away from my fingers.
I seem to recall at least one other Spyderco model with this issue and I hope they look for it in future designs, because if I didn't really like this knife it would likely be a deal-breaker. I can't imagine buying a knife knowing in advance that this was a "feature".
But what a slicer
I now wonder if it is actually the jimping or the sharp angle above the jimping section?Glad but sorry to hear one of my initial impressions about the Ikuchi was confirmed. As earlier suggested, the best way to avoid the abrasiveness of the flipper dial is to use your index fingernail to engage it or just to a compression tab release wrist flick.
The "other" Spyderco model that I believe that you are referring to in terms of the "risk" of being cut is the Tropen. I have never been cut by the Tropen but the "risk" exists and there are people who have reported being cut by it. However, from what I've seen/read, the risk is greater w/the Ikuchi IF the tip of the blade rises above the edge of the liners, as it apparently does in some cases.
I fortunately do not have that problem w/mine and anyone who does should return it to the dealer they bought it from or to Spyderco for repair, if you can't make the necessary adjustments yourself.
Where was this solution mentioned in this thread? I can't seem to find it. I wouldn't mind hearing more about this, it sounds like a good fix.Thanks Colorodo
I took the gray Spyderco stones to the tip of the spine and rounded it a bit.
That pretty much takes care of the bite problem with it. Sucks to do that to a new knife, but it's an easy fix.
Post #25Where was this solution mentioned in this thread? I can't seem to find it. I wouldn't mind hearing more about this, it sounds like a good fix.
I personally like it better then my boos. But I've always loved the feel of Taichungs cf over g10. Then again I really dislike carbon fiber. Even swapped out the cf for aluminum on my 940-1, and made a all titanium black and white 0450-minus-cf hybrid. My experience might not be yours is what I'm saying.
But damn what a great grind on this blade. Perfectly centered too, awesome bevels and perhaps the sharpest spyderco out of the factory yet for me. It's a bit too sharp at the wheel though, is there already a general consensus as to how to best remedy this without losing too much traction?
