I'm going to take a medium rod across the wheel then and be gentle about it, thanks for the input!
The knife fires far more reliable after cleaning it and putting decent lube on there.
I came across a bigger issue however.
I couldn't quite manage to get my ikuchi to perfect centering, and I was lost on the cause. I've taken apart every knife I own and centered many Benchmades and the odd spydie over the years so I like to think I know what I'm doing. Upon further inspection I noticed the liner where the comp lock protrudes from was bend slightly. Crazy. When left flat on a glass table either the top or the bottom would be raised a millimeter off the surface.
I've managed to remedy the worst of it, and it's far better now (and the action leaves nothing to be desired), but I've never ever had issues like this. Returning it seems overkill as I'm sure this can be remedied and the lack of supply means it'll be shipped to spyderco and back meaning I'm out one fresh ikuchi for a month - or maybe
2 (eu to states and back).
I could not find similar cases so I reckon I'm unfortunate, if they were in good supply I'd
definitely return it.
Are there any guides or tips as to how to get a straight liner without damaging its structural strength? The fact that the compression lock is on this liner makes me not want to take chances with it too much. If decent tips arise I'll post a picture next time I take it apart, otherwise I'll leave it as is because it's action is smooth and well adjusted without blade play (a notch tighter then desired though). If the compression lock is held down a flick downwards will reliably close it effortlessly, but just knowing about that one liner is annoying me, I know it's sub-optimal and I like to tweak my knives till I get a perfect balance in action and solidity in build (forgive my English Haha).
Edit:
It's hard to photograph correctly but there is slightly more space between the liner holding the compression lock and the blade then opposite on the clip side, yet near optimal centering is achieved. A side of me says to let sleeping dogs lie as I don't know what complications might arise from trying to set a slightly bended liner back straight, new territory and all. I've got a pretty good idea of what to do but theory and practice work out quite different most of the time.
Pic
Edit 2 better pictures:
It's not hard to see what's going on here when knowing the cause.
I'm over my initial disappointment on this front and carried it quite a bit, it's a very sexy little thing and eventually I'll likely buy a backup as well as I do with most of my favorite knives (and it's affordable to boot)
