Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Hi folks, took some shots of the steps I go through when I make a paracord lanyard for my knives, the Diamond knot is very handy knot to learn to make, there are youtube videos on the subject as well, so I suggest searching out those when you can, but here are some main points to be aware of when making them.
Sometimes it's not easy to get the paracord through the hole, so I will slice the paracord at an angle and then carefully melt that with a lighter to keep it from fraying, on some holes that are really small, I will remove some of the inner core strands JUST near the end so it will fold down smaller to get through the hole and pull hard to get the full paracord through.
Please ignore the blue stuff in the photos, that's tacky stickum to help keep the paracords in place while I take the photos
EDITED to say I changed out the first set of pictures to these with two colours of paracord to help see how they are threaded/knotted together better...
My 7 year old grandson gifted me this folder, gotta love grandkids like that !
I welded two colours of paracord, the weld spot is inside the knife handle, strong enough for this duty but you wouldn't want to hang from it.
lanyard1 by GaryWGraley, on Flickr
Here it shows I fold one side so they are side by side, and the other side gets a loop, but before you do that, take that strand of paracord and twist it two full turns, this will help prevent the lanyard being twisted when you go to tie the knot.
lanyard2 by GaryWGraley, on Flickr
Next you lay the twisted loop OVER top of the parallel loop
lanyard3 by GaryWGraley, on Flickr
Then take the one free end of the parallel loop side and bring that under the other side and then down through BOTH loops
lanyard4 by GaryWGraley, on Flickr
lanyard5 by GaryWGraley, on Flickr
Then bring that one BACK up through the top loop
lanyard6 by GaryWGraley, on Flickr
with some wriggling, you should end up with this pretzel looking design, notice the diamond shape in the middle
lanyard7 by GaryWGraley, on Flickr
Next we take the one side so it is continuing around and come up into that diamond hole area
lanyard8 by GaryWGraley, on Flickr
And take the other one, bring it along so it is also following the curve and take that one also through the diamond hole
lanyard9 by GaryWGraley, on Flickr
you will end up with what I call a World looking ball, it'll be awkward but will bring it into shape easily
lanyard10 by GaryWGraley, on Flickr
I use a pair of needle nose pliers to pull the cords tight, do this easy at first to get it down to where it's a ball, pulling on one side then the other side, equally, and finally pull them VERY tight, it becomes a hard knot
lanyard11 by GaryWGraley, on Flickr
In order to prevent the knot from swinging around the end of the handle into the area of the blade, I take some heavy thread and do what's called "Whipping" basically you make a loop that has one end back at one side, you will pull on that to bring the knot under the tightly wrapped thread.
Edited to say I pulled a strand from inside the paracord to use for the whipping on this one, just to see if it would work, as long as you have GOOD paracord, the inner threads should be good to work with.
Edited again to put this link here to show the where to get the black thread used on my usual ones.
lanyard12 by GaryWGraley, on Flickr
Just start wrapping and pulling the thread tight around the two strands, keeping that loop out near the knife, then cut the thread short and stick it through the loop
Yet another EDIT
a tip on doing this whipping, after you get several turns around the paracord, grab the one line of the loop, not the one you will pull later but the other one, and pull that up tight, that will SNUG up the starting wraps for you and make it all nice and tight when done...
lanyard13 by GaryWGraley, on Flickr
Pull the thread carefully, not too hard or you will pull it all the way out, just pull enough to get the loop under the wrapped thread and trim off the end sticking out on either side
lanyard15 by GaryWGraley, on Flickr
lanyard14 by GaryWGraley, on Flickr
lanyard16 by GaryWGraley, on Flickr
To end the loop of the lanyard with another diamond knot, do the same thing as before.
Tighten it up, if you have one side of the loop longer than the other, just adjust using the needle nose pliers to work the paracord through the knot before you tight it up fully. Here you see both diamond knots, I have to trim off the ends there and then with a lighter carefully melt the short ends down and quickly press that against some polished metal surface and rub and it will end up being a nice polished looking end of the knot
Adding this video of the diamond knot just made 12-20-23, I don't know why it went vertical but after several times making them, I just went with the last one
Hope that helps or at least gives you guys/gals some ideas to try.
And here is a link to a making a braided leather fob
G2
Yet another EDIT
G2
