Ingenious name! Love it.I call my Leading Edge sharpener " The Red Scorpion "
Having fun putting together the new updated clamps![]()
Does anyone know if there are some links to all the hardware?
I can find the brass inserts
Get some 1mm thick - hard, and use it bare.also have 1 mm thick.
Hey everyone -CelloDan - will be looking to buy more knives
You've created a very cool set up Dan. I'm certain that you will have great fun and razor sharp success with your new tool and accessories. It looks great to! Nicely dine.![]()
Awesome setup and great strops Dan! When you receive those pastes you'll be set for hair splitting edges.
You are expanding and improving your skills. Good to see.Today I sharpened and "reprofiled"a couple of chisels.
I am no carpenter by any means and these two chisels saw some significant abuse over the years on my part.
I usually use them to knock off some of the bark of live edge bowls before I mount them on the lathe.
I also used them to remove nails, as pry bars, to cut off half cured pieces of fiberglass and epoxy when I was building a boatetc etc etc .
Mamma Mia !
btw, here are some of the bowls I recently turned
So as I mentioned these two were in rough shape.
I cleaned the rust with CLR and lapped the bottoms on a few strips of sandpaper I glued to a piece of melamine I had laying around.
Because of their desperate state I had to take them to my slow speed grinder to true the edge and grind the main bevel making sure I did not overheat the steel
At this point I was ready to take them to my Leading Edge system.
What makes sense to me at this point is to just do a secondary smaller bevel on the concave grind produced by the grinder.
I did this one one of them but on the bigger one I sharpened the whole bevel just to see how it would turn out.
Zeroed the angle on the chisel
Looks like the original angle is around 30 degrees. I used my homemade lapping plates ( glass glued onto aluminum strips ) with the 3M abrasive films. I find that a very small amount of mineral oil works well as a lubricant on these films
After the first grit of 100 microns
( also noticed how the plastic clamp flexes a little, it is important not to over tighten it and use tape inside the clamp to aid in securing the chisel )
After the 9 micron film.
Two sharp chisels.
(I realized after that the secondary bevel on the smaller one is a little too steep.)
For occasional touch ups on these chisels, the Leading Edge system is all I need as I can use the stones/film/ diamond paste strops etc that I already use for my knives.
SHARP![]()
