Hi again folks
I'll share a few more "pics and tips"
of the sharpener and it's assembly.
The parts are 3D printed, of course.
I printed a few smaller parts at my local library but for most of them I used Treatstock, a well established and affordable online printing service
( I built two systems )
For print settings I used 50 % infill ( the amount of plastic inside the piece) with 5 walls or shells ( the outer solid layers ).
Here are the parts:
You will need melt in brass threaded inserts like this one for all the M4 screws and M4 thumb screws :
( links for parts are in the you tube video description posted above )
The trick is to installed them properly on the first try as it is hard to rectify a mistake once it's in.
I screw the insert on a long M4 screw flush at the tip. You then heat up the insert with a small torch or lighter for a few seconds ( count to 10 ). Not hot enough and it will not melt in ... too hot is not good either as the plastic is quite soft actually. You may need to practice two or three times on the small stopper rings so print a few extra.
When you are ready, install the insert keeping it straight until just a hair below the rim of the hole. At this point I found it best to ask someone to spray a little water on the insert with a spray bottle while I hold everything in perfect position. It will steam a little ( so keep your finger clear of other holes in the piece ) and will cool quickly. If its not straight or not deep enough you can heat up the screw itself, thread it into the insert on adjust it.
If you don't have an assistant, carefully cool the piece under running water while keeping everything straight.
Finish by fully threading the screw in and out to clear any melted plastic that may be in the way.
