- Dec 30, 2005
Which one would you recommend, and why?
Definitely the Spirit. It's the best multitool I've ever used, by quite a large margin. Far superior to any of Leatherman's offerings, in my opinion. The craftsmanship of the Spirit is simply astounding, and the design is very, very good. All of the tools are smooth as butter. The pliers have given me no problems. I actually like having that small serrated blade, to supplement my larger plain edged folder. The Spirit is extremely rust resistant, unlike the many Leatherman's and Gerber's I've owned. The saw totally rocks. There is always a screwdriver sized correctly for the job at hand. The Spirit is an easier carry than the hordes of large and heavy multitools out there. The file isn't diamond coated, but does what I need of it. The scissors are a tad small, but big enough for most the jobs I need it for. The grip is very comfortable. The locking system is easy to use.
I searched over ten years for that perfect multitool. I finally found the Spirit, and haven't looked back.
Cobalt is correct about the better steel in the blade on the Charge. The lock, however, is not nearly as well done on the Charge, IMO -- and I'm not an anti-liner lock guy.
154 CM is better than the steel in the Spirit ... but the Spirit is a master piece!
Although I have not used or carried the spirit, I see no advantage to it over what I just mentioned and unless it has those same features I would say that the Charge Ti has it. Oh, the Chrge Ti has an 154CM blade if I am not mistaken a vast improvement over the typical cheaper steel most multitools use.
