- Jan 14, 2000
The only thing about it that suggests “gentleman’s folder” is the clean aesthetic.
I agree.
That is why I pulled the trigger on it. Hoping it will be in that size slot with my Large Inkosi and Umnumzaan, for days I want a flipper. Never had a real Laconico, but this gives me a chance to test the water. Found one on the exchange with natural blasted finish, and portals.I would like this knife more if it were smaller. I think the design would be more attractive as a "mini." It looks like an over-sized gentleman's knife.
(stock photo)
The combination of Laconico design and WE manufacturing makes for a terrific knife. And top-notch quality at a modest price.
I just wish for a 3 inch (even better: 2:99 inch) version.
The Kizer version of the Yorkie should be out pretty soon. That might scratch the itch for you! I'm definitely gonna have to try one out I think. Love the look of that little blade. Wish they had left out the hole in the middle of the front scale, though.
Exactly my feeling.
The MBK EZC is going to be 3” blade (under 3” cutting edge) with 3 3/4” handle and a groove instead of the hole/s. Still Kizer production, same milled ti clip as the Yorkie, and a spear point blade.
I think the Yorkie may have a .12” thick blade vs expecting .16” on the EZC, though.
Why are Laconicos all so damned short? Is it a knife law issue?
I have a Keen and it is indeed 3.5". I tend to think of 4" or 100mm as full-sized. Perhaps because many municipalities prohibit 4-inch or larger knives that defines large and small for me.The Keen is full size, 3.5'' blade at least.
Thanks for showing me those. I wasn't aware. It's interesting but any blade config other than FFG doesn't quite fit his minimalist design aesthetic. They look a bit common after eyeing all of his other designs.The Intrepid is full size, as well as the LV (Laconico + Vagnino) Lancer 2.
...Thanks for showing me those. I wasn't aware. It's interesting but any blade config other than FFG doesn't quite fit his minimalist design aesthetic. They look a bit common after eyeing all of his other designs...
I will respectfully disagree here. For my work purposes 4-inch utility blades dominate. 3.5" to 4.5" can be the range but much outside that it's either too small or too cumbersome for my personal preference.You can do the same things with a 3” blade that you can with a 4” blade, for example.
This was a 5-inch Kramer-Zwillings that I broke the tip off of a few months ago. I just got around to grinding it down, re-profiling the edge and making a new tip. It's just a hair over 4 5/8-inch now but because of the choil choking up on the grip makes it work like a shorter blade. Without the choil the new cutting edge is 4 3/8-inches. I like it much better than when it was new. Works for me.
I don't know what carbon steel was used but it's soft enough to have made reshaping the blade enjoyable.
