We had a big organization and communication problem before all this. It was never really a problem until things compounded recently. That has been a big time suck. Between bad books, sorting through email, dealing with PayPal, and moving money around it has taken much longer than it should have for a few customers. I've put this out there and been honest about it in every response I've posted anywhere. Some refunds went out a couple thousand dollars at a time. I can't just make that money magically appear, especially since you can clearly see we haven't been selling knives based on the last knife posted on our website.
As far as the cutting or Waterjet debate it's really pretty simple. I've been making knives a long time. I've cut many blanks On a band saw, then a manual mill, etc. they don't offer any advantage to the knife or the customer (actually the opposite). It offers no, repeat no advantage to the customer. Water cutting the blanks offers many advantages to the customer. If your talking about locating holes being a skill, that was true 70-100 years ago, but based on your IG page you also use CAD to design your folders. You locate your holes there then print templates for your material cut outs on the band saw, correct? If not, then why check for function of your design in CAD. CAD = Holes located. I make all of our knives, design all of our knives, do all the 2D and 3D CAD for our knives, make all of our knives function, etc. The only thing that happens during water jet is a 2D part gets cut out of a 2D sheet of material off of my CAD designs. We don't have people making designs for us. You still have to grind locks, fit locks, grind blades, bevels, handles, profile, set detents, drill detent holes, set stop pins, manually mill features and counterbores, and in and on. You could argue all year about it, just like I can argue why tip down isn't as good as tip up.
There was an argument much like this a few years ago in the knife community. If a you made a knife via stock removal it wasn't really hand made, especially if you used a jig to grind. The argument was a blank had to be forged to be hand made. Same with Damascus. Same argument in the community about "hand ground customs," and "midtechs" and, tip up or tip down, and so on. I do just as much as you do by hand in my shop except sit behind a bandsaw. As an engineer I would think that you could see the many different advantages aesthetically, and through function, strength, and efficiency of having a lock bar on a folder water cut. If we're arguing about having fixed blade blanks cut then it's ridiculous. Drilling holes and forcing material through a band saw isn't a skill. What you do with the knife after you get the blank cut is the only part that requires even a little skill. Anyone can be taught to make a knife. It's not magic. You're not a part of some special part of humanity because you can make a knife. They've been around for centuries.
If I was CNC'ing ever piece to completion I could see the problem. Some knives are made that way and they cost twice, to three times more than our knives.
