You'll like it, but lemme warn ya, its gonna need some work. Yes, they can be out to the task right off, but they are way. better after some finicky work. Some sanding of the blade slot to widen it out, then sanding around the pivot area for some more clearance. They some immersion is either mineral oil, or better yet, melt some kind of wax/grease into the joint area. I've done Vasoline jelly, Johnson's floor wax, chap stick, and they all work. I use the wife's blow drier on hot and melt it, then jam more in, and Melt that in. That makes it a lot more water resistant. Then use a very large mill file to drop the point just a bit so its more of a strait clip point. Final step is to sand down the upper fishtail of the butt of the handle so it fits the hand better. A little sanding of the handle so the blade can be pinched to pull out and not need the nail nick.
You may have to adjust the locking ring for easy rotation if its too tight.
Yeah, its a a lot of trouble, but they do cut like the dickens. Theres something almost sensual in the way that blade glides through stuff. Its kind of like a kit car thats a PITA to get road ready, but its all about the engine! This knife is all about the blade.
