- Nov 10, 2015
People who actually posted in this thread should be given priority for a chance to buy, since I’m guessing these would be limited and highly sought after.
Top Craftsmanship and top materials cost money.
Count me in for a light saber..
A CPK design, in delta 3V, of a similar style or maybe slightly smaller, even though made in a larger quantity, should also bring a reasonable price for the amount of work that would go into it. Unless we’re talking a slightly modified Behemoth, I think $1000 is too low, to be fair. The competition cutters at $700 were an incredible, incredible, value.
I know these prices are out of range for many, so I don’t mean to come off as all hoity-toity, but in all fairness to CPK, yes, I’d pay $1000 and significantly upwards for a design that drew me in. Mike
Excellent Information-Thank YouMike nailed it, here.
Despite not using the same methods to make a knife, I think I have enough insight into making blades in the alloys we’re talking about to offer my input.
CPM-4v/Vanadis4Extra, and to a lesser extent CPM3v are expensive to work with, and it’s not the steel that’s expensive, it’s the abrasives (and perhaps cutting tools? dunno. have to ask Nathan about increased carbide cutter wear, here). These steels eat grinding belts, and even though Nathan does the bull work with endmills, you still have to eliminate tool marks with belts - they don’t tumble out. I believe Nathan and crew are also setting the final geometry with belts.
Belts are REALLY expensive.
REALLY REALLY REALLY expensive. And with these alloys, they last seconds before they’re shot.
No, that’s not a typo or an exaggeration.
To provide an example, I prefer using 3m 707e ceramic belts for 220 grit. They’re one of the few belts that cut with any consistency with high vanadium steels. They’re $6 each, and I usually need to use a few on a 5” kwaiken with a 1” high primary bevel. That’s to get a clean 220 grit finish on a relatively small blade, with a short blade height.
Just winging it here, but I’ll wager an 18” blade with around a 2-1/2” height would double the number of belts needed to finish the primary bevel compared to the competition choppers, which I’ll also go out on a limb and guess used a record number of belts to finish.
This doesn’t speak to the fact that it takes TIME to use these belts to apply these finishes.
I’m not sure I see how it could be done in the poll’s specified range. Just my two cents.![]()
That territory is already under new management, poaching Johns there will only result in you getting your pretty face cut. You are relegated to where you started your career, the three feet between the dumpster and the back of the building behind the truck stop.EDIT: Please give me a 2 or 3 month "Heads UP" on the KOD Knife, I am presently in negotiations to get my Street Corner Position reinstated![]()
Guess your right, that is where I fell most comfortable and "at Home"That territory is already under new management, poaching Johns there will only result in you getting your pretty face cut. You are relegated to where you started your career, the three feet between the dumpster and the back of the building behind the truck stop.
I agree "Ding Me"this knife would require a top edge, imo
