This is true. Sometimes you can put the drive in neutral and rev the engine to build pressure, then work a little, then back to neutral...If my personal experience tells me anything, it is likely a failing check valve in the hydraulics, and the rental company won't bother fixing it until the thing won't pick up a load at all.
I think you're right.If my personal experience tells me anything, it is likely a failing check valve in the hydraulics, and the rental company won't bother fixing it until the thing won't pick up a load at all.
Damn, that sucks.goddamnmotherfuckingpieceofshitforklift lift truck isn't working properly, droops under a load, won't hold a seven ton load. We're dead-in-the-water again. Except the shop is tore apart and there is a machining center sitting outside...
Oh well, at least it's dry out today.
Guess we'll work on sharpening tomorrow
Wash, rinse, repeat
Tradesfolk are funny.
That piece of equipment NTM is using would technically be called a telescopic handler or telescopic forklift. I’ve never heard it called that on a job. In Ohio it’s a gradall. Gradall is actually a company that used to produce those machines - it’s possible they still do.
An articulating boom lift is commonly referred to as a snorkel boom. Snorkelift is again, a manufacturer.
I had a hell of a time when I moved from the Midwest to the Pacific Northwest. I was a foreman so I had to order parts at the end of everyday. My first week was horrible. What I call unistrut, they called kindorf.
What I call old work tins, they called battleships.
After the first week I would just hold up an example of what I needed and would ask my crew, “What do you call this?”
Things got better from there on.
Kindorf??? That's a new one on me!What I call unistrut, they called kindorf.
Holy crap today was a long day
Your killing me. Did you get everything moved?Holy crap today was a long day
