- Dec 11, 2014
That's too funny Jack. The "lost in translation" thing really holds true and offers a good chuckle.
Thanks! I noticed some Congress, Swell Center, and Sowbelly patterns among others. I've never had a Congress, so that'd be another first (which is always good, variety is the spice of life).If you're not looking to modify the knives first, I'd recommend something like a congress pattern. You normally get a good selection of whittling friendly blades in that pattern. Plus the blades in most of the Rough Rider congress knives are smaller and thinner giving you good blades for fine detail. Look for something in a comfortable handle length too as that can really be a deal breaker.
I started with a Colt railsplitter that I like but have run into the limitations of the large blades once or twice. I meant to grind the blades down but never got to that. I did take the edges down to 15-17° per side and went pretty high polish.
All I have to do now is strop to keep it sharp even with hardwood.
Good luck on whittling and hopefully Mr Chips will be by to set me straight
I'm looking to try a little whittling, and would like to get my first "whittler". Which Rough Rider model would you guys suggest? I really don't even have a clue what blade combos are best.
I definitely like the look of that, especially with the hidden tang/angle or whatever you call it. I'm a bit over picky about that when using knives hard.I second Neko2's suggestion of a congress (and his recommendation to get input from Mr. Chips ). I enjoy my amateur whittling attempts, and my projects are usually small enough to carry around in a coat pocket so I can work on them at the bus stop before and after work. So small blades work better for me. I'm quite fond of this little Rough Rider canoe-whittler. It's only 3 inches long, which might be uncomfortably small for long sessions, but for the 15-20 minutes at a time that I usually whittle, it hasn't been a problem. The main blade (2 inches) is a lockback spearpoint, and it also has 1.5" pen and coping blades; nice variety of sizes and shapes.
- GT
Looks like Rough Rider has a new Cotton Sampler out. Looks pretty nice.
Love me some cotton samplers.....
Another little thing - I noticed it in my own pictures - the Case grind stops right at the spine where as the RRs are thinner, causing a step at the plunge line in the spine. I don't know if it's good, bad, or indifferent, but I guess I would rather have the material on the knife than in a pile of metal dust on the factory floor...
Nice photos!
I'm not sure that I follow and I'm not familiar with this particular pattern but in the photos it looks like the blades are offset on the RRs. This helps make space to accommodate the 2nd blade. The Case knife appears to have a double liner for this purpose... at least that's my guess without seeing the wells with the blades closed.
Where did you find those spirt daggers? Metal or stone blades?
They might go well in a Dream Catcher, or something.
